[GRASS-dev] [GRASS GIS] #612: g.html2man: parsing leads to man page errors
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Docs | Version: 6.4.0 RCs
Keywords: g.html2man | Platform: Unspecified
      Cpu: All |
tools/g.html2man has a number of parsing problems.
there are a few like cairodriver.1 which happen to start lines with ".",
which gets parsed incorrectly by the man program. e.g. in cairodriver it
lists ouput formats, and the '.pn' of .png gets hijacked and all those
image types end up missing from the resulting man page.
another popular one is <OL><LI> becoming ..IP instead of .IP (e.g.
pngdriver.1 just after "Example")
and yet another is g.parser.1 where #%multiple: gets eaten.
detailed list of errors is here: (scroll down to 'grass-doc')
http://lintian.debian.org/maintainer/pkg-grass-
devel@lists.alioth.debian.org.html#grass
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612&gt;
Resolution: | Keywords: g.html2man
  Platform: Unspecified | Cpu: All
Comment (by glynn):
Replying to [ticket:612 hamish]:
I've committed some fixes in r37386. Apart from escaping dots and single
quotes at the beginning of a line, it doesn't remove leading whitespace
from pre-formatted text and doesn't insert line breaks within .IP "..."
(this last one only affected d.graph).
I can't reproduce these.
Note that the "bad whatis" entries correspond to an HTML file which lacks
a description in the NAME section. This generally only occurs with HTML
files which aren't generated from --html-description.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:1&gt;
Comment (by hamish):
Also there is a zillion cases of -flag and --flag using '-' so interpreted
as a hyphen not a minus sign. i.e. '-' must be quoted as '\-'. See:
http://lintian.debian.org/tags/hyphen-used-as-minus-sign.html
I looked, but I've got no idea how to backport this stuff to the perl
version. does the perl version still need to be there in trunk?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 hamish]:
interpreted as a hyphen not a minus sign. i.e. '-' must be quoted as '\-'.
See:
How is the script supposed to determine whether a '-' in the HTML is a
minus or a hyphen? For now, I've changed it to convert all occurrences of
'-' to '\-'.
No.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:3&gt;
Replying to [comment:3 glynn]:
> is a minus or a hyphen?
fwiw, lintian's perl detection goes like:
http://ftp.de.debian.org/debian/pool/main/l/lintian/lintian_2.2.10.tar.gz
# Catch hyphens used as minus signs by looking for ones at the
# beginning of a word, but don't generate false positives on \s-1
# (small font), \*(-- (pod2man long dash), or things like \h'-1'.
     if ($line =~ /^(
                     [\s\'\"\`\(\
                     (?<! \\s | \*\( | \(- | \w\' )
                     (--?\w+)/ox) {
> For now, I've changed it to convert all occurrences of '-' to '\-'.
ok; cosmetic rendering errors are better than syntax ones I guess.
cheers,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:4&gt;
some fixes for non-module help pages (were causing 'mandb -c' whatis
errors) in devbr6 and trunk in r37877, ..
hope for testing feedback before backporting to 6.4.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 hamish]:
The changes are meaningless; g.html2man.py discards all comments.
To get a suitable whatis entry, the HTML file needs to include a
{{{<h2>NAME</h2>}}} section containing the module name followed by a dash
then the description. This is added automatically by --html-description,
but non-module pages will need to have it added manually.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:6&gt;
Replying to [comment:6 glynn]:
a few qualifiers on that are appropriate: a) currently; b) just for the
python version in gr7. (the perl version in all Gr versions now knows
about it)
the solution I used in the perl version was to check for that meta tag
before the comment stripping code.
> a {{{<h2>NAME</h2>}}} section containing the module name
> followed by a dash then the description. This is added
> automatically by --html-description, but non-module pages will
yeah, I look at doing that first. But the <H2>NAME really wasn't
appropriate for the intro and driver custom HTML pages I looked at and so
I went with the meta-tag solution.
I couldn't see how to make that work with the python version (does
HTMLParser.py strip out the comments before we can get our hands on
them?), and so I left it for now.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:7&gt;
Comment (by glynn):
Replying to [comment:7 hamish]:
I'm not so sure.
> and so I went with the meta-tag solution.
Actual <meta> tags would be a reasonable solution for any files which
genuinely shouldn't have a NAME section, e.g.
<meta name="name" content="grass-dbf" scheme="GRASS">
It's possible to add a handler for comments, but I don't consider this
appropriate.
Comments are comments; you are supposed to be able to use them as you
wish, without any consequences. The only situation where it's appropriate
for an application to take note of comments in its input is if it intends
to include them as comments in its output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:8&gt;
Reporter: hamish | Owner: grass-dev@…
Component: Docs | Version: svn-trunk
      Cpu: All |
Changes (by neteler):
  * version: 6.4.0 RCs => svn-trunk
  * milestone: 6.5.0 => 7.0.0
Comment:
(since related to g.html2man.py, bumping to trunk)
Ticket URL: <http://trac.osgeo.org/grass/ticket/612#comment:9&gt;
Component: Docs | Version: svn-develbranch6
      Cpu: All |
Changes (by hamish):
  * version: svn-trunk => svn-develbranch6
  * milestone: 7.0.0 => 6.5.0
Comment:
Actually the situation (rewritten) .py version is better, this bug has to
do with the Perl version in 6.x.
see
  scroll down to the "grass-doc" package and see the many warnings about
`manpage-has-bad-whatis-entry` and `manpage-has-errors-from-man`.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/612#comment:10&gt;
Keywords: g.html2man, utf8 | Platform: Unspecified
      Cpu: All |
  * keywords: g.html2man => g.html2man, utf8
Comment:
(G6.x only)
re. `man` treating flag names as hyphens and breaking them for cut & paste
when utf8 is used, here's some post-processing sed regex to catch many of
them:
sed -i -e 's/\([ (\)-\([a-z]\)/\1\\-\2/g' \
        -e 's/\([ \)--\([a-z]\)/\1\\-\\-\2/g' \
        -e 's/\[-\\fB/[\\-\\fB/' \
        -e 's/\[--\\fB/[\\-\\-\\fB/g' \
        -e 's/"\\fB-\([a-zA-Z0-9]\)/"\\fB\\-\1/' \
        -e 's/"\\fB--\([a-zA-Z0-9]\)/"\\fB\\-\\-\1/' \
        "$man_page"
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/612#comment:11&gt;
