[GRASS-dev] [GRASS GIS] #613: clean_temp: not safe for concurrent use
  Reporter: hamish | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.6.0
Component: Startup | Version: 6.4.0 RCs
Resolution: | Keywords: clean_temp init grass.py
       CPU: All | Platform: All
Comment (by wenzeslaus):
My current understanding is that that `clean_temp` is called in `grass.py`
right when it checks if it determines that it is not a new user which is
taken as a reason to clean the current mapset. Unfortunately the current
mapset is the last used mapset, not necessarily the one requested. The
mapset locking happens later on and only after that we can clean the
mapset. Therefore, I will move the `clean_temp` call only after the lock.
Note: There is another `clean_temp` at the end. My assumption is that the
start time one is meant to clean the mapset just in case.
Ticket URL: <https://trac.osgeo.org/grass/ticket/613#comment:4&gt;
