[GRASS-dev] [GRASS GIS] #614: r.proj method=cubic_f passes nulls
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: svn-develbranch6
Keywords: r.proj | Platform: Linux
      Cpu: x86-32 |
Running r.proj with method=cubic_f should not propagate NULLs, yet I still
get some.
In this set of commands the Northern Hemisphere reprojects properly, but
the Southern Hemisphere gets a diagonal row of NULLs from the upper right
to lower left of the region.
  http://grass.osgeo.org/wiki/Earth_at_night
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/614&gt;
Resolution: | Keywords: r.proj
  Platform: Linux | Cpu: x86-32
Comment (by hamish):
... happens along 180 longitude ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/614#comment:1&gt;
Comment (by kyngchaos):
Since cubic_f is essentially a patch of cubic,bilinear,nearest, only nulls
left from nearest should pass thru (propagate).
...testing...
Looks like it happens with cubic, bilinear AND nearest also. So it's not
the fallback logic.
Ticket URL: <https://trac.osgeo.org/grass/ticket/614#comment:2&gt;
