#616: TIFFMergeFieldInfo not found
Reporter: djj007 | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
Just installed the GRASS, and try to launch it.
I got a problem straight on. With the message for python: Entry point
TIFFMergeFieldInfo could not be found in the DLL libtiff.dll
And I have the following happening on the sh window:
Welcome to GRASS 6.4.0svn (2009)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: x86-32
Comment (by hamish):
is this the OSGeo4W installer or the stand-alone one?
(you are missing the libtiff library; or it it has gone out of date with
the one that was used to build your copy of grass; or your system is using
a copy of it already installed on your system from something else instead
of the one that ships with grass)
Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => worksforme
Old description:
Any idea??
New description:
