[GRASS-dev] [GRASS GIS] #618: rfe: r.md5sum or equivalent
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: Raster | Version: svn-trunk
Keywords: testsuite, r.univar, md5sum | Platform: All
      Cpu: All |
It would be helpful for comparing maps if there was some r.md5sum or
equivalent.
Actually I think a new flag for r.univar might be all that is needed.
presently this is what we got, and it's a bit less than optimal,
especially for quickly running through a test suite
r.mapcalc diff=map1-map2
r.univar diff
g.remove diff
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/618&gt;
Resolution: | Keywords: testsuite, r.univar, md5sum
  Platform: All | Cpu: All
Old description:
equivalent.
r.univar diff
g.remove diff
thanks,
Hamish
New description:
It would be helpful for comparing maps if there was some r.md5sum module
or equivalent.
especially for quickly running through a test suite:
r.univar diff
g.remove diff
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:1&gt;
Comment (by hamish):
see also [source:grass/trunk/testsuite/raster/raster_md5test.sh] for a
r.out.ascii | md5sum solution
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:2&gt;
Comment (by glynn):
Replying to [ticket:618 hamish]:
or equivalent.
What '''exactly''' should this module compute? MD5 and other hash
algorithms operate on a sequence of bytes, so you need to decide exactly
how to serialise the data.
Should it operate upon the raw map data, or after reclassing, MASKing, and
clipping and resampling according to the current region? How are nulls
represented? Are numeric values serialised big-endian, little-endian, or
in the host's native format? Or as decimal values in ASCII?
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:3&gt;
- for this task we care about data not how it is stored, so probably after
endian translation
  - not sure if the differences in how FPs are stored makes this an
impossiblity. (false negatives)
  - probably for this task we care about entire map not subregion(?) so not
clipped to current region. or maybe you want to check that a subregion is
the same (eg r.patch result..)
H
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:4&gt;
  Reporter: hamish | Owner: grass-dev@…
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: testsuite, r.univar, md5sum
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
done as g.md5sum addon, see source:grass-addons/grass6/general/g.md5sum
Ticket URL: <https://trac.osgeo.org/grass/ticket/618#comment:5&gt;
