#621: v.in.mapgen: add cats to lines
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: Vector | Version: svn-trunk
Keywords: v.in.mapgen, ascii | Platform: All
Cpu: All |
it would be nice if v.in.mapgen would add sequentially increasing cat
numbers to the lines it imports. currently all lines are without cat.
either by simply running `v.category opt=add` after the import or
by modifying the awk script to create cat numbers directly in the
v.in.ascii file.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/621>
