#623: compiling error grass6-devel - winvista 32
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
fresh svn-checkout at rev37604
compiling at winvista32 following
http://trac.osgeo.org/grass/wiki/CompileOnWindows
configure seems to be ok:
GRASS is now configured for: i686-pc-mingw32
Source directory: /c/osgeo4w/usr/src/grass6_devel
Build directory: /c/osgeo4w/usr/src/grass6_devel
Installation directory: ${prefix}/grass-6.5.svn
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: no
OpenGL platform: Windows
MacOSX application: no
NVIZ: yes
BLAS support: no
C++ support: yes
Cairo support: no
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: no
GLw support: no
JPEG support: yes
LAPACK support: no
Large File support (LFS): yes
Motif support: no
MySQL support: no
NLS support: yes
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: yes
Python support: no
Readline support: no
SQLite support: yes
Tcl/Tk support: yes
wxWidgets support: no
TIFF support: yes
X11 support: no
but a lot compiling errors:
GRASS GIS compilation log
Started compilation: Sat May 30 10:25:35 GMT 2009
Errors in:
/c/osgeo4w/usr/src/grass6_devel/lib/gis
/c/osgeo4w/usr/src/grass6_devel/lib/gmath
/c/osgeo4w/usr/src/grass6_devel/lib/linkm
/c/osgeo4w/usr/src/grass6_devel/lib/driver
/c/osgeo4w/usr/src/grass6_devel/lib/pngdriver
/c/osgeo4w/usr/src/grass6_devel/lib/psdriver
/c/osgeo4w/usr/src/grass6_devel/lib/raster
/c/osgeo4w/usr/src/grass6_devel/lib/bitmap
/c/osgeo4w/usr/src/grass6_devel/lib/btree
/c/osgeo4w/usr/src/grass6_devel/lib/display
/c/osgeo4w/usr/src/grass6_devel/lib/db/dbmi_base
/c/osgeo4w/usr/src/grass6_devel/lib/db/dbmi_client
/c/osgeo4w/usr/src/grass6_devel/lib/db/stubs
/c/osgeo4w/usr/src/grass6_devel/lib/db/dbmi_driver
/c/osgeo4w/usr/src/grass6_devel/lib/db/sqlp
/c/osgeo4w/usr/src/grass6_devel/lib/vask
/c/osgeo4w/usr/src/grass6_devel/lib/edit
/c/osgeo4w/usr/src/grass6_devel/lib/external/shapelib
/c/osgeo4w/usr/src/grass6_devel/lib/form
/c/osgeo4w/usr/src/grass6_devel/lib/imagery
/c/osgeo4w/usr/src/grass6_devel/lib/cluster
/c/osgeo4w/usr/src/grass6_devel/lib/proj
/c/osgeo4w/usr/src/grass6_devel/lib/rowio
/c/osgeo4w/usr/src/grass6_devel/lib/segment
/c/osgeo4w/usr/src/grass6_devel/lib/vector/rtree
/c/osgeo4w/usr/src/grass6_devel/lib/vector/dglib
/c/osgeo4w/usr/src/grass6_devel/lib/vector/diglib
/c/osgeo4w/usr/src/grass6_devel/lib/vector/Vlib
/c/osgeo4w/usr/src/grass6_devel/lib/vector/transform
/c/osgeo4w/usr/src/grass6_devel/lib/vector/vedit
/c/osgeo4w/usr/src/grass6_devel/lib/sites
/c/osgeo4w/usr/src/grass6_devel/lib/rst/data
/c/osgeo4w/usr/src/grass6_devel/lib/rst/qtree
/c/osgeo4w/usr/src/grass6_devel/lib/rst/interp_float
/c/osgeo4w/usr/src/grass6_devel/lib/g3d
/c/osgeo4w/usr/src/grass6_devel/lib/gpde
/c/osgeo4w/usr/src/grass6_devel/lib/dspf
/c/osgeo4w/usr/src/grass6_devel/lib/symbol
/c/osgeo4w/usr/src/grass6_devel/lib/init
/c/osgeo4w/usr/src/grass6_devel/lib/cdhc
/c/osgeo4w/usr/src/grass6_devel/lib/stats
/c/osgeo4w/usr/src/grass6_devel/lib/arraystats
/c/osgeo4w/usr/src/grass6_devel/lib/ogsf
/c/osgeo4w/usr/src/grass6_devel/lib/nviz
/c/osgeo4w/usr/src/grass6_devel/db/drivers/dbf
/c/osgeo4w/usr/src/grass6_devel/db/drivers/postgres
/c/osgeo4w/usr/src/grass6_devel/db/drivers/sqlite
/c/osgeo4w/usr/src/grass6_devel/db/drivers/ogr
/c/osgeo4w/usr/src/grass6_devel/db/base
/c/osgeo4w/usr/src/grass6_devel/db/db.login
/c/osgeo4w/usr/src/grass6_devel/display/d.ask
/c/osgeo4w/usr/src/grass6_devel/display/d.barscale
/c/osgeo4w/usr/src/grass6_devel/display/d.colorlist
/c/osgeo4w/usr/src/grass6_devel/display/d.colors
/c/osgeo4w/usr/src/grass6_devel/display/d.colortable
/c/osgeo4w/usr/src/grass6_devel/display/d.erase
/c/osgeo4w/usr/src/grass6_devel/display/d.extend
/c/osgeo4w/usr/src/grass6_devel/display/d.extract
/c/osgeo4w/usr/src/grass6_devel/display/d.font
/c/osgeo4w/usr/src/grass6_devel/display/d.frame
/c/osgeo4w/usr/src/grass6_devel/display/d.geodesic
/c/osgeo4w/usr/src/grass6_devel/display/d.graph
/c/osgeo4w/usr/src/grass6_devel/display/d.grid
/c/osgeo4w/usr/src/grass6_devel/display/d.his
/c/osgeo4w/usr/src/grass6_devel/display/d.histogram
/c/osgeo4w/usr/src/grass6_devel/display/d.info
/c/osgeo4w/usr/src/grass6_devel/display/d.legend
/c/osgeo4w/usr/src/grass6_devel/display/d.linegraph
/c/osgeo4w/usr/src/grass6_devel/display/d.mapgraph
/c/osgeo4w/usr/src/grass6_devel/display/d.measure
/c/osgeo4w/usr/src/grass6_devel/display/d.menu
/c/osgeo4w/usr/src/grass6_devel/display/d.mon/cmd
/c/osgeo4w/usr/src/grass6_devel/display/d.mon/pgms
/c/osgeo4w/usr/src/grass6_devel/display/d.nviz
/c/osgeo4w/usr/src/grass6_devel/display/d.paint.labels
/c/osgeo4w/usr/src/grass6_devel/display/d.path
/c/osgeo4w/usr/src/grass6_devel/display/d.profile
/c/osgeo4w/usr/src/grass6_devel/display/d.rast
/c/osgeo4w/usr/src/grass6_devel/display/d.rast.arrow
/c/osgeo4w/usr/src/grass6_devel/display/d.rast.num
/c/osgeo4w/usr/src/grass6_devel/display/d.rgb
/c/osgeo4w/usr/src/grass6_devel/display/d.rhumbline
/c/osgeo4w/usr/src/grass6_devel/display/d.save
/c/osgeo4w/usr/src/grass6_devel/display/d.text.new
/c/osgeo4w/usr/src/grass6_devel/display/d.thematic.area
/c/osgeo4w/usr/src/grass6_devel/display/d.title
/c/osgeo4w/usr/src/grass6_devel/display/d.vect
/c/osgeo4w/usr/src/grass6_devel/display/d.vect.chart
/c/osgeo4w/usr/src/grass6_devel/display/d.what.rast
/c/osgeo4w/usr/src/grass6_devel/display/d.what.vect
/c/osgeo4w/usr/src/grass6_devel/display/d.where
/c/osgeo4w/usr/src/grass6_devel/display/d.zoom
/c/osgeo4w/usr/src/grass6_devel/general/g.access
/c/osgeo4w/usr/src/grass6_devel/general/g.ask
/c/osgeo4w/usr/src/grass6_devel/general/g.dirseps
/c/osgeo4w/usr/src/grass6_devel/general/g.filename
/c/osgeo4w/usr/src/grass6_devel/general/g.findetc
/c/osgeo4w/usr/src/grass6_devel/general/g.findfile
/c/osgeo4w/usr/src/grass6_devel/general/g.gisenv
/c/osgeo4w/usr/src/grass6_devel/general/g.gui
/c/osgeo4w/usr/src/grass6_devel/general/g.mapset
/c/osgeo4w/usr/src/grass6_devel/general/g.mapsets
/c/osgeo4w/usr/src/grass6_devel/general/g.message
/c/osgeo4w/usr/src/grass6_devel/general/g.mkfontcap
/c/osgeo4w/usr/src/grass6_devel/general/g.mlist
/c/osgeo4w/usr/src/grass6_devel/general/g.mremove
/c/osgeo4w/usr/src/grass6_devel/general/g.parser
/c/osgeo4w/usr/src/grass6_devel/general/g.proj
/c/osgeo4w/usr/src/grass6_devel/general/g.pnmcomp
/c/osgeo4w/usr/src/grass6_devel/general/g.region
/c/osgeo4w/usr/src/grass6_devel/general/g.setproj
/c/osgeo4w/usr/src/grass6_devel/general/g.tempfile
/c/osgeo4w/usr/src/grass6_devel/general/g.transform
/c/osgeo4w/usr/src/grass6_devel/general/g.version
/c/osgeo4w/usr/src/grass6_devel/general/manage/cmd
/c/osgeo4w/usr/src/grass6_devel/general/manage/lister
/c/osgeo4w/usr/src/grass6_devel/gui/scripts
/c/osgeo4w/usr/src/grass6_devel/gui/wxpython/scripts
/c/osgeo4w/usr/src/grass6_devel/imagery/i.ask
/c/osgeo4w/usr/src/grass6_devel/imagery/i.cluster
/c/osgeo4w/usr/src/grass6_devel/imagery/i.find
/c/osgeo4w/usr/src/grass6_devel/imagery/i.gensig
/c/osgeo4w/usr/src/grass6_devel/imagery/i.gensigset
/c/osgeo4w/usr/src/grass6_devel/imagery/i.group
/c/osgeo4w/usr/src/grass6_devel/imagery/i.his.rgb
/c/osgeo4w/usr/src/grass6_devel/imagery/i.maxlik
/c/osgeo4w/usr/src/grass6_devel/imagery/i.rectify
/c/osgeo4w/usr/src/grass6_devel/imagery/i.rgb.his
/c/osgeo4w/usr/src/grass6_devel/imagery/i.smap/shapiro
/c/osgeo4w/usr/src/grass6_devel/imagery/i.target
/c/osgeo4w/usr/src/grass6_devel/imagery/i.pca
/c/osgeo4w/usr/src/grass6_devel/imagery/i.cca
/c/osgeo4w/usr/src/grass6_devel/imagery/i.atcorr
/c/osgeo4w/usr/src/grass6_devel/imagery/i.fft
/c/osgeo4w/usr/src/grass6_devel/imagery/i.ifft
/c/osgeo4w/usr/src/grass6_devel/imagery/i.zc
/c/osgeo4w/usr/src/grass6_devel/misc/m.cogo
/c/osgeo4w/usr/src/grass6_devel/ps/ps.map
/c/osgeo4w/usr/src/grass6_devel/raster/r.average
/c/osgeo4w/usr/src/grass6_devel/raster/r.basins.fill
/c/osgeo4w/usr/src/grass6_devel/raster/r.bilinear
/c/osgeo4w/usr/src/grass6_devel/raster/r.bitpattern
/c/osgeo4w/usr/src/grass6_devel/raster/r.buffer
/c/osgeo4w/usr/src/grass6_devel/raster/r.carve
/c/osgeo4w/usr/src/grass6_devel/raster/r.cats
/c/osgeo4w/usr/src/grass6_devel/raster/r.circle
/c/osgeo4w/usr/src/grass6_devel/raster/r.clump
/c/osgeo4w/usr/src/grass6_devel/raster/r.coin
/c/osgeo4w/usr/src/grass6_devel/raster/r.colors
/c/osgeo4w/usr/src/grass6_devel/raster/r.composite
/c/osgeo4w/usr/src/grass6_devel/raster/r.compress
/c/osgeo4w/usr/src/grass6_devel/raster/r.contour
/c/osgeo4w/usr/src/grass6_devel/raster/r.cost
/c/osgeo4w/usr/src/grass6_devel/raster/r.covar
/c/osgeo4w/usr/src/grass6_devel/raster/r.cross
/c/osgeo4w/usr/src/grass6_devel/raster/r.describe
/c/osgeo4w/usr/src/grass6_devel/raster/r.distance
/c/osgeo4w/usr/src/grass6_devel/raster/r.drain
/c/osgeo4w/usr/src/grass6_devel/raster/r.external
/c/osgeo4w/usr/src/grass6_devel/raster/r.fill.dir
/c/osgeo4w/usr/src/grass6_devel/raster/r.flow
/c/osgeo4w/usr/src/grass6_devel/raster/r.grow2
/c/osgeo4w/usr/src/grass6_devel/raster/r.grow.distance
/c/osgeo4w/usr/src/grass6_devel/raster/r.gwflow
/c/osgeo4w/usr/src/grass6_devel/raster/r.horizon
/c/osgeo4w/usr/src/grass6_devel/raster/r.his
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.arc
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.ascii
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.bin
/c/osgeo4w/usr/src/grass6_devel/raster/r.info
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.gridatb
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.mat
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.poly
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.xyz
/c/osgeo4w/usr/src/grass6_devel/raster/r.kappa
/c/osgeo4w/usr/src/grass6_devel/raster/r.lake
/c/osgeo4w/usr/src/grass6_devel/raster/r.le/r.le.patch
/c/osgeo4w/usr/src/grass6_devel/raster/r.le/r.le.pixel
/c/osgeo4w/usr/src/grass6_devel/raster/r.le/r.le.setup
/c/osgeo4w/usr/src/grass6_devel/raster/r.le/r.le.trace
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.daemon
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.edgedensity
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.patchdensity
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.patchnum
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.shape
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.simpson
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.shannon
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.mps
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.mpa
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.padcv
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.padsd
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.padrange
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.cwed
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.richness
/c/osgeo4w/usr/src/grass6_devel/raster/r.li/r.li.dominance
/c/osgeo4w/usr/src/grass6_devel/raster/r.los
/c/osgeo4w/usr/src/grass6_devel/raster/r.mapcalc
/c/osgeo4w/usr/src/grass6_devel/raster/r.median
/c/osgeo4w/usr/src/grass6_devel/raster/r.mfilter
/c/osgeo4w/usr/src/grass6_devel/raster/r.mfilter.fp
/c/osgeo4w/usr/src/grass6_devel/raster/r.mode
/c/osgeo4w/usr/src/grass6_devel/raster/r.neighbors
/c/osgeo4w/usr/src/grass6_devel/raster/r.null
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.arc
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.ascii
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.bin
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.gridatb
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.mat
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.mpeg
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.pov
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.ppm
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.ppm3
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.vrml
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.vtk
/c/osgeo4w/usr/src/grass6_devel/raster/r.param.scale
/c/osgeo4w/usr/src/grass6_devel/raster/r.patch
/c/osgeo4w/usr/src/grass6_devel/raster/r.profile
/c/osgeo4w/usr/src/grass6_devel/raster/r.proj.seg
/c/osgeo4w/usr/src/grass6_devel/raster/r.quant
/c/osgeo4w/usr/src/grass6_devel/raster/r.quantile
/c/osgeo4w/usr/src/grass6_devel/raster/r.random
/c/osgeo4w/usr/src/grass6_devel/raster/r.random.cells
/c/osgeo4w/usr/src/grass6_devel/raster/r.random.surface
/c/osgeo4w/usr/src/grass6_devel/raster/r.reclass
/c/osgeo4w/usr/src/grass6_devel/raster/r.recode
/c/osgeo4w/usr/src/grass6_devel/raster/r.region
/c/osgeo4w/usr/src/grass6_devel/raster/r.report
/c/osgeo4w/usr/src/grass6_devel/raster/r.resample
/c/osgeo4w/usr/src/grass6_devel/raster/r.resamp.interp
/c/osgeo4w/usr/src/grass6_devel/raster/r.resamp.rst
/c/osgeo4w/usr/src/grass6_devel/raster/r.resamp.stats
/c/osgeo4w/usr/src/grass6_devel/raster/r.rescale
/c/osgeo4w/usr/src/grass6_devel/raster/r.rescale.eq
/c/osgeo4w/usr/src/grass6_devel/raster/r.series
/c/osgeo4w/usr/src/grass6_devel/raster/r.slope.aspect
/c/osgeo4w/usr/src/grass6_devel/raster/r.statistics
/c/osgeo4w/usr/src/grass6_devel/raster/r.stats
/c/osgeo4w/usr/src/grass6_devel/raster/r.sum
/c/osgeo4w/usr/src/grass6_devel/raster/r.sun2
/c/osgeo4w/usr/src/grass6_devel/raster/r.sunmask
/c/osgeo4w/usr/src/grass6_devel/raster/r.support/modcats
/c/osgeo4w/usr/src/grass6_devel/raster/r.support/modcolr
/c/osgeo4w/usr/src/grass6_devel/raster/r.support/modhist
/c/osgeo4w/usr/src/grass6_devel/raster/r.support/modhead
/c/osgeo4w/usr/src/grass6_devel/raster/r.support/front
/c/osgeo4w/usr/src/grass6_devel/raster/r.support.stats
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.area
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.contour
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.idw
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.idw2
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.random
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.gauss
/c/osgeo4w/usr/src/grass6_devel/raster/r.texture
/c/osgeo4w/usr/src/grass6_devel/raster/r.thin
/c/osgeo4w/usr/src/grass6_devel/raster/r.timestamp
/c/osgeo4w/usr/src/grass6_devel/raster/r.to.rast3
/c/osgeo4w/usr/src/grass6_devel/raster/r.to.rast3elev
/c/osgeo4w/usr/src/grass6_devel/raster/r.to.vect
/c/osgeo4w/usr/src/grass6_devel/raster/r.topidx
/c/osgeo4w/usr/src/grass6_devel/raster/r.topmodel
/c/osgeo4w/usr/src/grass6_devel/raster/r.transect
/c/osgeo4w/usr/src/grass6_devel/raster/r.univar2
/c/osgeo4w/usr/src/grass6_devel/raster/r.volume
/c/osgeo4w/usr/src/grass6_devel/raster/r.walk
/c/osgeo4w/usr/src/grass6_devel/raster/r.water.outlet
/c/osgeo4w/usr/src/grass6_devel/raster/r.watershed/ram
/c/osgeo4w/usr/src/grass6_devel/raster/r.watershed/seg
/c/osgeo4w/usr/src/grass6_devel/raster/r.watershed/front
/c/osgeo4w/usr/src/grass6_devel/raster/r.what
/c/osgeo4w/usr/src/grass6_devel/raster/r.what.color
/c/osgeo4w/usr/src/grass6_devel/raster/simwe/simlib
/c/osgeo4w/usr/src/grass6_devel/raster/simwe/r.sim.water
/c/osgeo4w/usr/src/grass6_devel/raster/simwe/r.sim.sediment
/c/osgeo4w/usr/src/grass6_devel/raster/wildfire/r.ros
/c/osgeo4w/usr/src/grass6_devel/raster/wildfire/r.spread
/c/osgeo4w/usr/src/grass6_devel/raster/wildfire/r.spreadpath
/c/osgeo4w/usr/src/grass6_devel/raster/r.in.gdal
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.gdal
/c/osgeo4w/usr/src/grass6_devel/raster/r.surf.fractal
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.png
/c/osgeo4w/usr/src/grass6_devel/raster/r.terraflow
/c/osgeo4w/usr/src/grass6_devel/raster/r.out.tiff
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.cross.rast
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.in.ascii
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.in.v5d
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.gwflow
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.mkdspf
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.out.ascii
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.out.v5d
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.out.vtk
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.stats
/c/osgeo4w/usr/src/grass6_devel/raster3d/r3.to.rast
/c/osgeo4w/usr/src/grass6_devel/raster3d/base
/c/osgeo4w/usr/src/grass6_devel/vector/v.buffer2
/c/osgeo4w/usr/src/grass6_devel/vector/v.build
/c/osgeo4w/usr/src/grass6_devel/vector/v.build.polylines
/c/osgeo4w/usr/src/grass6_devel/vector/v.category
/c/osgeo4w/usr/src/grass6_devel/vector/v.class
/c/osgeo4w/usr/src/grass6_devel/vector/v.clean
/c/osgeo4w/usr/src/grass6_devel/vector/v.convert
/c/osgeo4w/usr/src/grass6_devel/vector/v.db.connect
/c/osgeo4w/usr/src/grass6_devel/vector/v.db.select
/c/osgeo4w/usr/src/grass6_devel/vector/v.delaunay2
/c/osgeo4w/usr/src/grass6_devel/vector/v.distance
/c/osgeo4w/usr/src/grass6_devel/vector/v.drape
/c/osgeo4w/usr/src/grass6_devel/vector/v.edit
/c/osgeo4w/usr/src/grass6_devel/vector/v.extract
/c/osgeo4w/usr/src/grass6_devel/vector/v.extrude
/c/osgeo4w/usr/src/grass6_devel/vector/v.generalize
/c/osgeo4w/usr/src/grass6_devel/vector/v.hull
/c/osgeo4w/usr/src/grass6_devel/vector/v.info
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.ascii
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.db
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.dxf
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.region
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.sites
/c/osgeo4w/usr/src/grass6_devel/vector/v.kcv
/c/osgeo4w/usr/src/grass6_devel/vector/v.kernel
/c/osgeo4w/usr/src/grass6_devel/vector/v.label
/c/osgeo4w/usr/src/grass6_devel/vector/v.lrs/lib
/c/osgeo4w/usr/src/grass6_devel/vector/v.lrs/v.lrs.create
/c/osgeo4w/usr/src/grass6_devel/vector/v.lrs/v.lrs.segment
/c/osgeo4w/usr/src/grass6_devel/vector/v.lrs/v.lrs.label
/c/osgeo4w/usr/src/grass6_devel/vector/v.lrs/v.lrs.where
/c/osgeo4w/usr/src/grass6_devel/vector/v.proj
/c/osgeo4w/usr/src/grass6_devel/vector/v.mkgrid
/c/osgeo4w/usr/src/grass6_devel/vector/v.neighbors
/c/osgeo4w/usr/src/grass6_devel/vector/v.net
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.alloc
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.iso
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.path
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.salesman
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.steiner
/c/osgeo4w/usr/src/grass6_devel/vector/v.net.visibility
/c/osgeo4w/usr/src/grass6_devel/vector/v.normal
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.ascii
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.dxf
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.pov
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.svg
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.vtk
/c/osgeo4w/usr/src/grass6_devel/vector/v.overlay
/c/osgeo4w/usr/src/grass6_devel/vector/v.parallel2
/c/osgeo4w/usr/src/grass6_devel/vector/v.patch
/c/osgeo4w/usr/src/grass6_devel/vector/v.perturb
/c/osgeo4w/usr/src/grass6_devel/vector/v.split
/c/osgeo4w/usr/src/grass6_devel/vector/v.qcount
/c/osgeo4w/usr/src/grass6_devel/vector/v.random
/c/osgeo4w/usr/src/grass6_devel/vector/v.reclass
/c/osgeo4w/usr/src/grass6_devel/vector/v.sample
/c/osgeo4w/usr/src/grass6_devel/vector/v.segment
/c/osgeo4w/usr/src/grass6_devel/vector/v.select
/c/osgeo4w/usr/src/grass6_devel/vector/v.support
/c/osgeo4w/usr/src/grass6_devel/vector/v.surf.idw
/c/osgeo4w/usr/src/grass6_devel/vector/v.surf.rst
/c/osgeo4w/usr/src/grass6_devel/vector/v.transform
/c/osgeo4w/usr/src/grass6_devel/vector/v.to.3d
/c/osgeo4w/usr/src/grass6_devel/vector/v.to.db
/c/osgeo4w/usr/src/grass6_devel/vector/v.to.points
/c/osgeo4w/usr/src/grass6_devel/vector/v.to.rast
/c/osgeo4w/usr/src/grass6_devel/vector/v.to.rast3
/c/osgeo4w/usr/src/grass6_devel/vector/v.type
/c/osgeo4w/usr/src/grass6_devel/vector/v.univar
/c/osgeo4w/usr/src/grass6_devel/vector/v.voronoi
/c/osgeo4w/usr/src/grass6_devel/vector/v.what
/c/osgeo4w/usr/src/grass6_devel/vector/v.what.rast
/c/osgeo4w/usr/src/grass6_devel/vector/v.vol.rst
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/lidarlib
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/v.surf.bspline
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/v.outlier
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/v.lidar.correction
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/v.lidar.edgedetection
/c/osgeo4w/usr/src/grass6_devel/vector/lidar/v.lidar.growing
/c/osgeo4w/usr/src/grass6_devel/vector/v.out.ogr
/c/osgeo4w/usr/src/grass6_devel/vector/v.in.ogr
/c/osgeo4w/usr/src/grass6_devel/vector/v.external
/c/osgeo4w/usr/src/grass6_devel/vector/v.digit
/c/osgeo4w/usr/src/grass6_devel/vector/v.label.sa
/c/osgeo4w/usr/src/grass6_devel/visualization/nviz
/c/osgeo4w/usr/src/grass6_devel/visualization/nviz2/cmd
switching in just a few of all the directories with errors
syringia@NADA /c/osgeo4w/usr/src/grass6_devel/lib/gis
$ make
make OBJ.i686-pc-mingw32
make[1]: Entering directory `/c/osgeo4w/usr/src/grass6_devel/lib/gis'
make[1]: `OBJ.i686-pc-mingw32' is up to date.
make[1]: Leaving directory `/c/osgeo4w/usr/src/grass6_devel/lib/gis'
gcc -I/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/include
-I/c/OSGeo4W/include -g -O2 -I/c/OSGeo4W/include
-DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64 -DGDAL_LINK=1
-DGDAL_DYNAMIC=1 -DPACKAGE=\""grasslibs"\" -I/c/OSGeo4W/include
-I/c/OSGeo4W/include -I/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32/include -o OBJ.i686-pc-mingw32/spawn.o -c spawn.c
spawn.c:224: warning: "struct spawn" declared inside parameter list
spawn.c:224: warning: its scope is only this definition or declaration,
which is probably not what you want
spawn.c: In function `do_spawn':
spawn.c:229: error: dereferencing pointer to incomplete type
spawn.c:230: error: dereferencing pointer to incomplete type
spawn.c:233: error: dereferencing pointer to incomplete type
spawn.c:233: warning: passing arg 4 of `spawnvpe' from incompatible
pointer type
spawn.c:235: error: dereferencing pointer to incomplete type
spawn.c: In function `G_vspawn_ex':
spawn.c:626: warning: passing arg 1 of `do_spawn' from incompatible
pointer type
spawn.c:626: error: too few arguments to function `do_spawn'
spawn.c: In function `G_spawn_ex':
spawn.c:649: warning: passing arg 1 of `do_spawn' from incompatible
pointer type
spawn.c:649: error: too few arguments to function `do_spawn'
make: *** [OBJ.i686-pc-mingw32/spawn.o] Error 1
syringia@NADA /c/osgeo4w/usr/src/grass6_devel/lib/gmath
$ make
gcc -shared -o /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32/lib/libgrass_gmath.6.5.svn.dll
-L/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib -Wl,--export-
dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/lib OBJ.i686-pc-
mingw32/brent.o OBJ.i686-pc-mingw32/dalloc.o OBJ.i686-pc-mingw32/del2g.o
OBJ.i686-pc-mingw32/eigen.o OBJ.i686-pc-mingw32/eigen_tools.o OBJ.i686-pc-
mingw32/fft.o OBJ.i686-pc-mingw32/findzc.o OBJ.i686-pc-mingw32/gauss.o
OBJ.i686-pc-mingw32/getg.o OBJ.i686-pc-mingw32/ialloc.o OBJ.i686-pc-
mingw32/jacobi.o OBJ.i686-pc-mingw32/la.o OBJ.i686-pc-mingw32/lu.o OBJ.
i686-pc-mingw32/max_pow2.o OBJ.i686-pc-mingw32/mult.o OBJ.i686-pc-
mingw32/rand1.o OBJ.i686-pc-mingw32/svd.o -lgrass_gis -lgrass_datetime
-lxdr -liberty -lws2_32 -lz -lintl -lfftw3 ../../lib/gis/OBJ.
i686-pc-mingw32/dllmain.o && \
(cd /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib; ln -f -s
libgrass_gmath.6.5.svn.dll /c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32/lib/libgrass_gmath.dll)
gcc.exe: ../../lib/gis/OBJ.i686-pc-mingw32/dllmain.o: No such file or
directory
make: *** [/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-
mingw32/lib/libgrass_gmath.6.5.svn.dll] Error 1
syringia@NADA /c/osgeo4w/usr/src/grass6_devel/db/drivers/dbf
$ make
gcc -L/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib -Wl,
--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/lib -o
/c/osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/driver/db/dbf.exe
OBJ.i686-pc-mingw32/column.o OBJ.i686-pc-mingw32/cursor.o OBJ.i686-pc-
mingw32/db.o OBJ.i686-pc-mingw32/dbfexe.o OBJ.i686-pc-mingw32/describe.o
OBJ.i686-pc-mingw32/driver.o OBJ.i686-pc-mingw32/error.o OBJ.i686-pc-
mingw32/execute.o OBJ.i686-pc-mingw32/fetch.o OBJ.i686-pc-
mingw32/listtab.o OBJ.i686-pc-mingw32/main.o OBJ.i686-pc-mingw32/select.o
OBJ.i686-pc-mingw32/str.o OBJ.i686-pc-mingw32/table.o OBJ.i686-pc-
mingw32/create_table.o ../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o
-lgrass_dbmidriver -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr
-liberty -lws2_32 -lz -lintl -lgrass_dbstubs -lgrass_dbmibase
-lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz -lintl
-lgrass_dbmibase -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32
-lz -lintl -lgrass_sqlp -lgrass_shape -lgrass_dbstubs
-lz -lintl -lgrass_gis -lgrass_datetime -lxdr -liberty -lws2_32 -lz
-lintl -lgrass_datetime -lxdr -liberty -lws2_32 -lz
gcc.exe: ../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o: No such file or
directory
mingw32/driver/db/dbf.exe] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/623>
