[GRASS-dev] [GRASS GIS] #625: make errors (missing demolocation)
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: MSWindows Vista
      Cpu: x86-32 |
I get the following errors compiling trunk (r37704) though it worked fine
a couple days ago.
Errors in:
/src/trunk/db/db.columns
/src/trunk/db/db.connect
/src/trunk/db/db.copy
/src/trunk/db/db.createdb
/src/trunk/db/db.databases
/src/trunk/db/db.describe
/src/trunk/db/db.drivers
/src/trunk/db/db.dropdb
/src/trunk/db/db.droptable
/src/trunk/db/db.execute
/src/trunk/db/db.login
/src/trunk/db/db.select
/src/trunk/db/db.tables
/src/trunk/display/d.barscale
/src/trunk/display/d.colorlist
/src/trunk/display/d.colortable
... there's a lot more but they all have the same error message:
if [ "/src/trunk/dist.i686-pc-mingw32/bin/db.columns.exe" != "" ] ; then
GISRC=/src/trunk/dist.i686-pc-mingw32/demolocation/.grassrc70
GISBASE=/src/trunk/dist.i686-pc-mingw32 PATH="/src/trunk/dist.i686-pc-
mingw32/bin:$PATH" PYTHONPATH="c:\programs\gis\osgeo4w\usr\src\trunk\dist.
i686-pc-mingw32\etc\python;$PYTHONPATH" PATH="/src/trunk/dist.i686-pc-
mingw32/bin:/src/trunk/dist.i686-pc-mingw32/lib:/src/trunk/dist.i686-pc-
mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/PROGRA~1/COMMON~1/ULEADS~1/MPEG:/c/Programs/GIS/Subversion:/c/Program
Files/QuickTime/QTSystem/:/osgeo4w/apps/grass/bin:/bin:/c/Programs/Subversion"
LC_ALL=C /src/trunk/dist.i686-pc-mingw32/bin/db.columns.exe --html-
description < /dev/null | grep -v '</body>\|</html>' > db.columns.tmp.html
; fi
access: No such file or directory
ERROR: LOCATION << /src/trunk/dist.i686-pc-mingw32/demolocation >> not
        available
make: *** [db.columns.tmp.html] Error 1
rm db.columns.tmp.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/625&gt;
Resolution: | Keywords:
  Platform: MSWindows Vista | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:625 cnielsen]:
fine a couple days ago.
I've been making quite a lot of changes to the build system over the last
couple of days.
        available
Try this:
Index: include/Make/Grass.make
--- include/Make/Grass.make (revision 37704)
+++ include/Make/Grass.make (working copy)
@@ -48,7 +48,6 @@
  LIB_RUNTIME_DIR = $(GISBASE)/lib
  RUN_GISRC =
$(GISBASE)/demolocation/.grassrc$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)
-RUN_GISBASE = $(GISBASE)
  # these define the various directories which contain GRASS programs
Index: include/Make/Platform.make.in
--- include/Make/Platform.make.in (revision 37704)
+++ include/Make/Platform.make.in (working copy)
@@ -41,6 +41,7 @@
  INST_DIR = @INSTDIR@
  GRASS_HOME = @GRASS_HOME@
+RUN_GISBASE = @GISBASE@
  GRASS_VERSION_MAJOR = @GRASS_VERSION_MAJOR@
  GRASS_VERSION_MINOR = @GRASS_VERSION_MINOR@
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:1&gt;
Comment (by cnielsen):
New error:
Tue Jun 2 14:50:20 EDT 2009: STARTING make
include/Make/Vars.make:1: include/Make/Platform.make: No such file or
directory
make: *** No rule to make target `include/Make/Platform.make'. Stop.
directory
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 cnielsen]:
> New error:
directory
Can you provide more detail on where this is originating from, i.e. which
Makefile is generating this error?
The error implies that MODULE_TOPDIR isn't being set.
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:3&gt;
I can't seem to reproduce the second error, meaning probably my error.
demolocation error fixed with the patch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:4&gt;
Sorry Glynn, I had rolled back to an earlier version and that is why the
demolocation error seemed fixed. In fact the patch had no effect, the
error is still present.
$ make
GISBASE=c:/programs/gis/osgeo4w/usr/src/trunk/dist.i686-pc-mingw32
PATH="/src/trunk/dist.i686-pc-mingw32/bin:$PATH"
PYTHONPATH="c:\programs\gis\osgeo4w\usr\src\trunk\dist.i686-pc-
mingw32/lib:.:/usr/local/bin:/mingw/bin:/bin:/osgeo4w/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/PROGRA~1/COMMON~1/ULEADS~1/MPEG:/c/Programs/GIS/Subversion:/c/Programs/Online/QuickTime/QTSystem/:/osgeo4w/apps/grass/bin:/bin:/c/Programs/Subversion"
; fi
        available
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 cnielsen]:
        available
This should be fixed in r37808.
Ticket URL: <http://trac.osgeo.org/grass/ticket/625#comment:6&gt;
  Platform: All | Cpu: All
Changes (by hamish):
  * platform: MSWindows Vista => All
  * cpu: x86-32 => All
Comment:
I can reproduce something similar on amd64 Linux with r37899.
(pretty new Debian/Lenny)
the problem seems to be that the system type is not detected properly
("unknown" or ""), and build dirs end up called bin./ and dist./.
there is: "config.status.x86_64-unknown-linux-gnu"
for releasebranch_6_4 on the same machine I get: bin.x86_64-unknown-linux-
gnu/ and dist.x86_64-unknown-linux-gnu/ and it builds ok.
error is:
[...]grass/svn/trunk/dist./bin/db.login --html-description < /dev/null |
grep -v '</body>\|</html>' > db.login.tmp.html ; fi
ERROR: LOCATION <<
        /usr/src/grass/svn/trunk/dist.unknown/demolocation >> not
        available
make[2]: *** [db.login.tmp.html] Error 1
rm db.login.tmp.html
make[2]: Leaving directory `/usr/src/grass/svn/trunk/db/db.login'
make[1]: Leaving directory `/usr/src/grass/svn/trunk/db'
in the above note dist. != dist.unknown.
I had a look but couldn't see where in configure's uname magic it
determines the "unknown" type. Seems to be related to cross-compiling.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:7&gt;
Comment (by hamish):
same thing happens with develbranch6. relbr64 builds ok.
Platform.make's `ARCH =` line is empty.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:8&gt;
Comment (by glynn):
Replying to [comment:7 hamish]:
System detection is up to config.guess; we might need a newer version.
Are you sure that this isn't a leftover from a previous build?
linux-gnu/ and dist.x86_64-unknown-linux-gnu/ and it builds ok.
> error is:
ERROR: LOCATION << /usr/src/grass/svn/trunk/dist.unknown/demolocation >>
not available
# Set ARCH
ARCH=
if test -z "${host}"; then
ARCH="unknown"
else
ARCH="${host}"
fi
Note that Platform.make.in has:
ARCH = @host@
Although configure.in has:
AC_SUBST(ARCH)
ARCH isn't used in Platform.make.
Also, SC_CONFIG_FLAGS uses uname (which means that cross-compiling can't
work), while everything else uses $host.
Which reminds me that SC_CONFIG_FLAGS should have been discarded for 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:9&gt;
Replying to [comment:9 glynn]:
that's in the relbr6 (which builds). In devbr6 and trunk on the same
system it is called `config.status.unknown`.
> # Set ARCH
> ARCH=
> ARCH="unknown"
> else
> ARCH="${host}"
> fi
> ARCH = @host@
> AC_SUBST(ARCH)
7.0.
ok, following config.guess:
timestamp='2008-04-14'
UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}"
x86_64:Linux:2.6.26-2-amd64:#1 SMP Thu May 28 21:28:49 UTC 2009
...leads to
     x86_64:Linux:*:*)
         echo x86_64-unknown-linux-gnu
         exit ;;
I don't see where $host is set.
trunk$ ./configure reports:
checking host system type... x86_64-unknown-linux-gnu
Copying config.status to config.status.x86_64-unknown-linux-gnu
GRASS is now configured for: x86_64-unknown-linux-gnu
Platform.make now has:
ARCH = x86_64-unknown-linux-gnu
weird, this time it got it.
more tests tomorrow.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:10&gt;
Comment (by glynn):
Replying to [comment:10 hamish]:
It's set by AC_CANONICAL_HOST from the output of config.guess.
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:11&gt;
I think I figured out how I was getting "config.status.unknown".
it was because I messed up the ./configure line:
CFLAGS="-ggdb -march=amdfam10 -Wall -Werror-implicit-function-declaration"
   ./configure \
     --with-tcltk-includes=/usr/include/tcl8.5 --with-cairo \
     --with-motif --with-python=/usr/bin/python2.5-config \
     --with-readline --with-cxx --with-odbc --with-sqlite \
     --with-freetype --with-freetype-includes=/usr/include/freetype2 \
     --without-postgres --with-proj-share=/usr/share/proj \
     --enable-64bit --with-pthread \
     --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
     \ #--with-ffmpeg --with-ffmpeg-includes=/usr/include/ffmpeg \
     --with-geos \
     2>&1 | tee config_log.txt
` \ #comment` is a problem.. causes this to happen when you run
./configure:
configure: warning: #--with-ffmpeg: invalid host type
checking host system type... Invalid configuration `#--with-ffmpeg':
machine `#--with' not recognized
checking for gcc... gcc
I don't really understand why ./configure continues weirdly, but if I get
rid of the `\ #--with-ffmpeg` line it all builds ok.
sorry for hijacking this bug with a stupid mistake,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cnielsen):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:6 glynn]:
Error resolved, closing ticket. (Good to see Hamish's error is resolved
too)
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:13&gt;
Comment (by glynn):
Replying to [comment:12 hamish]:
./configure:
get rid of the `\ #--with-ffmpeg` line it all builds ok.
bash treats "\ "" as a literal space, not a word separator. This means
that the following # isn't at the beginning of a word, so it's treated as
a literal # character rather than starting a comment. The end result is an
argument of "{{{ #--with-ffmpeg}}}". As it's the first argument which
doesn't begin with a dash, it's treated as the host type.
Ticket URL: <https://trac.osgeo.org/grass/ticket/625#comment:14&gt;
