GDAL
October 7, 2009, 9:13pm
21
#629: WinGRASS: spaces in pathnames
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Installation | Version: 6.4.0 RCs
Resolution: | Keywords: wingrass, msys
Platform: MSWindows XP | Cpu: x86-32
Comment (by hellik):
> Invalid argument: can't _spawnl
> WARNING: Cannot open driver dbf
grass64.svn rev 39432 compiled in osgeo4w-stack
WinVista32
tested in nc-dataset
v.out.ogr with spaces in path:
(Wed Oct 07 22:58:02 2009)
v.out.ogr input=poi_names_wake@PERMANENT type=point dsn=C:\wd\test ogr
olayer=poi_names_wake_out
ERROR: Unable to start driver <dbf>
(Wed Oct 07 22:58:02 2009) Command finished (0 sec)
=> shape-file is exported, but empty
v.out.ogr with no spaces in path:
v.out.ogr input=poi_names_wake@PERMANENT type=point dsn=C:\wd\test_ogr
olayer=poi_names_wake_out2
(Wed Oct 07 23:05:24 2009) Command finished (0 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:21> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
October 7, 2009, 9:27pm
22
Replying to [comment:21 hellik]:
> WinVista32
new location:
g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: towgs84=577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232
ellipsoid: bessel
north: 2500
south: 2000
west: 500
east: 1000
nsres: 20
ewres: 20
rows: 25
cols: 25
cells: 625
new dem generated by r.surf.fractal
r.to.vect -s -v input=testdem@test output=testdemvect feature=area
Raster is not CELL, '-v' flag ignored, raster values will be written to
the table.
ERROR: Unable to open database <$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/> by
driver <dbf>
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:22> ;
GDAL
October 7, 2009, 10:42pm
23
Replying to [comment:22 hellik]:
in osgeo4w-stack, WinVista32
nc-dataset
g.copy vect=hospitals@PERMANENT,testhospitals2
Copy vector <hospitals@PERMANENT> to current mapset as <testhospitals2>
Unable to copy table <testhospitals2>
Cannot copy <hospitals@PERMANENT> to current mapset as <testhospitals2>
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:23> ;
GDAL
October 8, 2009, 8:24pm
24
Comment (by neteler):
There should be new debug output available if activated:
Please try for us:
g.gisenv set="DEBUG=2"
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:24> ;
GDAL
October 8, 2009, 10:41pm
25
Replying to [comment:24 neteler]:
> Please try for us:
g.copy vect=hospitals@PERMANENT,copy_hospital
Copy vector <hospitals@PERMANENT> to current mapset as <copy_hospital>
D2/2: Copy vector 'hospitals' in 'PERMANENT' to
'copy_hospital'
D2/2: copy C:\gisdata\grassdata/nc_spm_08/PERMANENT/vector/h
ospitals/coor to C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/coor
ospitals/head to C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/head
ospitals/hist to C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/hist
ospitals/topo to C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/topo
ospitals/cidx to C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/cidx
D1/2: Vect_open_old(): name = hospitals mapset= PERMANENT
update = 0
D1/2: Vect_set_thresh(): thresh = 0.000000
D1/2: dig_spidx_init()
D1/2: open format file: 'PERMANENT/vector/hospitals/frmt'
D1/2: Vector format: 0 (native)
D1/2: Vect__read_head(): vector = hospitals@PERMANENT
D1/2: Level request = 1
D1/2: Vect_open_old(): vector opened on level 1
D1/2: Vect_read_dblinks(): map = hospitals, mapset =
PERMANENT
D1/2: dbln file: C:\gisdata\grassdata/nc_spm_08/PERMANENT/ve
ctor/hospitals/dbln
D1/2: dbln: 1 hospitals cat
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/2: field = 1 name = (null), table = hospitals, key = cat,
database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver =
dbf
D1/2: Dblinks read
D1/2: Vect_open_old(): name = copy_hospital mapset= user1
update = 1
D1/2: open format file: 'user1/vector/copy_hospital/frmt'
D1/2: Vect__read_head(): vector = copy_hospital@user1
D1/2: Level request = 0
D1/2: Vect_open_topo(): name = copy_hospital mapset= user1
D1/2: get coor info: C:\gisdata\grassdata/nc_spm_08/user1/ve
ctor/copy_hospital/coor
D1/2: Info->size = 4654, Info->mtime = 1255041550
D2/2: Topo header: file version 5.0 , supported from GRASS
version 5.0
D2/2: byte order 0
D2/2: header size 142
D2/2: with_z 0
D2/2: coor size 4654
D1/2: Topo head: coor size = 4654, coor mtime = 0
D1/2: dig_load_plus()
version 5.0
D2/2: byte order 0
D2/2: with_z 0
D2/2: Vect_cidx_open(): name = copy_hospital mapset= user1
D1/2: Vect_open_old(): vector opened on level 2
D1/2: Vect_read_dblinks(): map = copy_hospital, mapset =
user1
D1/2: dbln file: C:\gisdata\grassdata/nc_spm_08/user1/vector
/copy_hospital/dbln
D1/2: Cannot open vector database definition file
D1/2: Vect_get_dblink(): link = 0
D1/2: Vect_default_field_info(): map = copy_hospital field =
1
D2/2: drv = dbf db = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
D1/2: Vect_write_dblinks(): map = copy_hospital, mapset =
user1
/copy_hospital/dbln
D1/2: 1 copy_hospital cat
D1/2: Dblinks written
D2/2: opendir
c:/OSGeo4W/apps/grass/grass-6.4.0svn\driver\db\
D2/2: dbmi_client/start startup:
"c:/OSGeo4W/apps/grass/grass-6.4.0svn\driver\db\dbf.exe"
Unable to copy table <copy_hospital>
D1/2: Vect_close(): name = hospitals, mapset = PERMANENT,
format = 0, level = 1
D1/2: close history file
D1/2: Vect_close(): name = copy_hospital, mapset = user1,
format = 0, level = 2
Cannot copy <hospitals@PERMANENT> to current mapset as <copy_hospital>
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:25> ;
GDAL
October 8, 2009, 11:40pm
26
Comment (by hamish):
hellik wrote:
D2/2: opendir c:/OSGeo4W/apps/grass/grass-6.4.0svn\driver\db\
G_convert_dirseps_to_host() added in r39450-2.
see http://thread.gmane.org/gmane.comp.gis.grass.user/31623/focus=31758
(ummm Markus, was that only committed locally?)
If that doesn't work, my next guess is that the leading and trailing \"
are being treated as a literal part of the program name. (?!)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:26> ;
GDAL
October 9, 2009, 12:52pm
27
Replying to [comment:26 hamish]:
grass64svn_relb
self compiled in osgeo4w in WinVista: rev39452
GISDBASE='C:\gisdata\grassdata';
LOCATION_NAME='nc_spm_08';
MAPSET='user1';
DEBUG='2';
GRASS_GUI='wxpython';
g.copy vect=hospitals@PERMANENT,testcopyhospital
Copy vector <hospitals@PERMANENT> to current mapset as <testcopyhospital>
'testcopyhospital'
/testcopyhospital/coor
/testcopyhospital/head
/testcopyhospital/hist
/testcopyhospital/topo
/testcopyhospital/cidx
update = 0
PERMANENT
ctor/hospitals/dbln
dbf
D1/2: Dblinks read
D1/2: Vect_open_old(): name = testcopyhospital mapset= user1
update = 1
D1/2: open format file: 'user1/vector/testcopyhospital/frmt'
D1/2: Vect__read_head(): vector = testcopyhospital@user1
D1/2: Vect_open_topo(): name = testcopyhospital mapset=
user1
ctor/testcopyhospital/coor
D1/2: Info->size = 4654, Info->mtime = 1255092687
version 5.0
D2/2: byte order 0
D2/2: with_z 0
version 5.0
D2/2: byte order 0
D2/2: with_z 0
D2/2: Vect_cidx_open(): name = testcopyhospital mapset=
user1
D1/2: Vect_read_dblinks(): map = testcopyhospital, mapset =
user1
/testcopyhospital/dbln
D1/2: Vect_default_field_info(): map = testcopyhospital
field = 1
D1/2: Vect_write_dblinks(): map = testcopyhospital, mapset =
user1
D1/2: 1 testcopyhospital cat
D2/2: dbDbmscap(): opendir
[c:\OSGeo4W\apps\grass\grass-6.4.0svn\driver\db\]
["c:\OSGeo4W\apps\grass\grass-6.4.0svn\driver\db\dbf.exe"]
Unable to copy table <testcopyhospital>
D1/2: Vect_close(): name = testcopyhospital, mapset = user1,
Cannot copy <hospitals@PERMANENT> to current mapset as <testcopyhospital>
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:27> ;
GDAL
October 10, 2009, 12:57am
28
ok, it looks like the extra \" may be to blame then. (if _spawnl() quotes
the argument [as it should] then you get ""...\dbf.exe"")
I'll reply here once a fix for that is submitted.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:28> ;
GDAL
October 10, 2009, 6:05am
29
extra quotes removed in r39456,7. try, try again....
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:29> ;
GDAL
October 10, 2009, 9:54am
30
Comment (by glynn):
Replying to [comment:28 hamish]:
quotes the argument [as it should] then you get ""...\dbf.exe"")
[http://msdn.microsoft.com/en-us/library/20y988d2(VS.80).aspx Microsoft's
documentation] says that the caller needs to quote arguments:
> Spaces embedded in strings may cause unexpected behavior; for example,
passing _spawn the string "hi there" will result in the new process
getting two arguments, "hi" and "there". If the intent was to have the new
process open a file named "hi there", the process would fail. You can
avoid this by quoting the string: "\"hi there\"".
'''However:''' it says "arguments", which doesn't necessarily apply to the
command name (and db_start_driver() invokes the driver with no arguments),
although it will apply to argv![0] (it shouldn't matter if argv![0] has
excess quotes, but if it doesn't have enough it will end up rolling over
into argv![1]).
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:30> ;
GDAL
October 10, 2009, 5:38pm
31
Replying to [comment:29 hamish]:
grass64svn_relb self compiled in osgeo4w in WinVista: rev39464
g.gisenv --v
MAPSET='user1';
DEBUG='0';
g.copy vect=hospitals@PERMANENT,copyhospital
Copy vector <hospitals@PERMANENT> to current mapset as <copyhospital>
seems to work :o)
best regards
helli
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:31> ;
GDAL
October 11, 2009, 4:49pm
32
Replying to [comment:31 hellik]:
> g.gisenv --v
> MAPSET='user1';
> DEBUG='0';
> seems to work :o)
update:
tested also now in the sqlite-mapset of nc-dataset with sqlite as the db-
backend
g.gisenv --v
MAPSET='sqlite';
g.copy vect=hospitals@PERMANENT,hospitalsqlite
Copy vector <hospitals@PERMANENT> to current mapset as <hospitalsqlite>
seems to also to work
best regards
helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:32> ;
GDAL
October 28, 2009, 9:29am
33
I can confirm that the "can't _spawnl" problem is gone (using the latest
winGRASS binary based on r39626).
Ticket URL: <http://trac.osgeo.org/grass/ticket/629#comment:33> ;
GDAL
January 9, 2010, 12:38am
34
see also #809
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:34> ;
GDAL
January 9, 2010, 10:52am
35
Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, msys
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
closing this bug as in general this lot seem to be taken care of and
before it morphs into the next set of windows bugs. those can start their
own, new tickets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:35> ;
GDAL
February 4, 2010, 9:44am
36
local copy of msys.bat with quoted variables committed to
mswindows/osgeo4w/ in r40817-9.
Ticket URL: <https://trac.osgeo.org/grass/ticket/629#comment:36> ;
