GDAL
February 21, 2008, 5:21pm
1
#63: r.los: patch to support earth curvature
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
Based on ideas from r.cva and prototype code from Andrea Antonello I have
added earth curvature support in r.los.
Please test.
Ticket URL: <http://trac.osgeo.org/grass/ticket/63> ;
GRASS GIS <http://grass.osgeo.org >
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
GDAL
February 21, 2008, 5:22pm
2
Resolution: | Keywords:
Changes (by neteler):
* type: defect => enhancement
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:1> ;
GDAL
February 24, 2008, 9:03pm
3
Comment (by neteler):
Any opinions on this?
http://trac.osgeo.org/grass/attachment/ticket/63/rlos_curv.diff
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:2> ;
GDAL
February 25, 2008, 1:24am
4
Comment (by hamish):
r.los/main.c:
@@ -109,9 +114,13 @@
opt6->type = TYPE_DOUBLE;
opt6->required = NO;
opt6->answer = "10000";
- opt6->options = "0-999999";
+ opt6->options = "0-9999999999";
opt6->description = _("Maximum distance from the viewing point
(meters)");
Why increase that so much?
At the top of Everest, the maximum theoretical distance to the horizon
would be about 3.86*sqrt(8850) = 350km = 350,000m.
http://mintaka.sdsu.edu/GF/explain/atmos_refr/horizon.html
make it 500000m?
Should all the new /* try to get the radius ... */ code live behind a
check for the -c flag? in case the proj stuff has problems.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:3> ;
GDAL
February 25, 2008, 10:07am
5
Comment (by hopfgartner):
The observer might be on an airplane or other aircraft vehicel
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:4> ;
GDAL
February 25, 2008, 10:11am
6
Replying to [comment:4 hopfgartner]:
Earth radius might be the ultimative limit, as far as refraction is not
considered.
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:5> ;
GDAL
February 25, 2008, 10:14am
7
Comment (by pkelly):
I've no comment on the maths of the curvature stuff, but I think the code
to find the ellpisoid radius should simply use
G_get_ellipsoid_parameters() and all the PROJ_INFO parsing and checking
for invalid values etc. is taken care of then.
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:6> ;
GDAL
March 18, 2008, 9:35am
8
Type: enhancement | Status: closed
Resolution: fixed | Keywords:
* status: new => closed
* resolution: => fixed
Comment:
I have simplified the ellipsoid stuff to:
if (curvature->answer){
/* try to get the radius the standard GRASS way from the libs */
G_get_ellipsoid_parameters (&aa, &e2);
if (aa == 0) {
/* since there was a problem, take a hardcoded radius */
G_warning(_("Problem to obtain current ellipsoid parameters,
using sphere (6370997.0)"));
aa = 6370997.00;
G_debug(3, "radius: %f", aa);
Updated earth curvature patch submitted as [c30614]
(http://trac.osgeo.org/grass/changeset/c30614 ).
Ticket URL: <http://trac.osgeo.org/grass/ticket/63#comment:7> ;
