[GRASS-dev] [GRASS GIS] #631: Discrepancies between tcl/tk and wxpython PROJ_INFO files
Reporter: voncasec | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: Projections, wxpython, tcltk | Platform: Unspecified
      Cpu: Unspecified |
I have been noticing some discrepancies in the PROJ_INFO files that are
created using Grass6.4 RC4 between the projection values option in the
tcltk interface and the location wizard option using the wxpython
interface.
For example, inputting the projection info:
Coordinate System=UTM
Datum=Nad27 - T04 (Transformation Parameters for Alaska)
Ellipse: Clark66
Zone=8
I get the following PROJ_INFO files created.
tcltk interface results:
datum: nad27
nadgrids: alaska
proj: utm
ellps: clark66
a: 6378206.4000000004
es: 0.0067686580
f: 294.9786982000
zone: 8
wxpython results:
name: Universe Transverse Mercator
proj: utm
ellps: clark66
zone: 8
no_defs: defined
The summary at the end of the wxpython location wizard method says the
proj.4 definition is:
+proj=utm, +zone=8, +a= 6378206.4000000004, +rf=294.9786982000, +dx=-22,
+dy=157.0, +dz=176.0, +no_defs, +nadgrids=alaska
but if I run g.proj -j -f, I get the following output (which matches the
PROJ_INFO file):
+proj=utm +no_defs +zone=8 +a=6378206.4 +rf=294.9786982 +to_meter=1
Ticket URL: <http://trac.osgeo.org/grass/ticket/631&gt;
Resolution: | Keywords: Projections, wxpython, tcltk
  Platform: Unspecified | Cpu: Unspecified
Old description:
interface.
Ellipse: Clark66
Zone=8
datum: nad27
nadgrids: alaska
proj: utm
ellps: clark66
es: 0.0067686580
f: 294.9786982000
zone: 8
wxpython results:
proj: utm
ellps: clark66
zone: 8
no_defs: defined
PROJ_INFO file):
New description:
interface.
Ellipse: Clark66
Zone=8
datum: nad27
nadgrids: alaska
proj: utm
ellps: clark66
es: 0.0067686580
f: 294.9786982000
zone: 8
wxpython results:
proj: utm
ellps: clark66
zone: 8
no_defs: defined
PROJ_INFO file):
Comment (by neteler):
(prettified original report)
I just wonder if it is a problem what "nad27" isn't in the wxpython
PROJ_INFO file
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:1&gt;
Comment (by cmbarton):
The wxPython GUI has a location wizard. The location wizard uses g.proj to
create the location and the PROJ_INFO file.
The TclTk GUI does not have a location wizard. The location was created by
???. Maybe by g.projection??? an EPSG code??? Something else??? These may
well make a different PROJ_INFO file.
The real question is are the locations different in terms of their
projection parameters. What happens when you run g.region -gp?
What you see in the PROJ4 string in the location wizard is the string that
goes into g.proj. It is based on what you picked.
A further question, what version of 6.4 are you using (when compiled) and
for what platform?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:2&gt;
Comment (by hamish):
please try again with the latest 6.4.0svn wx Location Wizard.
I'm pretty sure that this is fixed this now. (see #784, among others)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:3&gt;
(here the tcltk created region [runs g.setproj] was ok, but the wx
location wizard was losing the datum/ellipsoid info)
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:4&gt;
I am pretty sure this has been fixed now too. I reported this a while back, and I have since updated GRASS with no issues related to projections.
Casey
  Reporter: voncasec | Owner: grass-dev@lists.osgeo.org Type: defect | Status: new Priority: normal | Milestone: 6.4.0 Component: default | Version: unspecified Resolution: | Keywords: Projections, wxpython, tcltk
  Platform: Unspecified | Cpu: Unspecified --------------------------+-------------------------------------------------
Hamish
      Type: defect | Status: closed
Resolution: fixed | Keywords: Projections, wxpython, tcltk
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
comment from grass-dev:
back,
> Casey
So: closing, please reopen if still a problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/631#comment:5&gt;
