[GRASS-dev] [GRASS GIS] #637: Problems with paths in the TCL/TK Windows GUI
Reporter: marmai | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Tcl | Version: 6.4.0 RCs
Keywords: Tcl Window Gui path | Platform: MSWindows 2K
      Cpu: Unspecified |
Within the tcltk-GUI it is not possible to select a map within the
project:
When clicking 'Add vector layer', then on the icon in the lower part of
the
GIS Manager (tcltk-GUI) 'vector map to display'. Within the following pop-
up window
there are no maps listed. With the 'g.list type=vect' command entered in
the GIS.m window, all vector maps are listed as expected. And it is also
possible to show the maps by entering the names of the maps in the
'Vector map'- field in the lower part of the GIS Manager. Just selecting
with the icon is not possible.
Furthermore another path related problem with the tcltk-GUI:
Using the 'Show attribute data' button within the 'GIS Manager' window the
following command is sent to be executed:
db.select table=veg_buffer_1_dissolve
database=D:\daten\GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
For this command I get the following error in the output:
  BMI-DBF driver error:
  Cannot create dbf database:
  D:datenGISDataBase/demolocation/PERMANENT/dbf/
  Unable to open database
  <D:datenGISDataBase/demolocation/PERMANENT/dbf/>
Notice: the \ are gone!
By correcting the command manually (backslash to slash) to:
database=D:/daten/GISDataBase/demolocation/PERMANENT/dbf/ driver=dbf
everything works fine.
All was tested with the GRASS6.4.0RC3 and GRASS6.4svn-2 (OSGeo4W
installer)
Ticket URL: <http://trac.osgeo.org/grass/ticket/637&gt;
  Priority: critical | Milestone: 6.4.0
Resolution: | Keywords: Tcl Window Gui path, wingrass
  Platform: MSWindows 2K | Cpu: Unspecified
Changes (by hamish):
  * keywords: Tcl Window Gui path => Tcl Window Gui path, wingrass
  * priority: normal => critical
Comment:
Replying to [ticket:637 marmai]:
> the project:
> part of the GIS Manager (tcltk-GUI) 'vector map to display'.
> Within the following pop-up window there are no maps listed.
> With the 'g.list type=vect' command entered in the GIS.m window,
> all vector maps are listed as expected. And it is also possible
> Just selecting with the icon is not possible.
confirmed with the latest wingrass installer (Colin's stand alone version
is much newer than the current osgeo4w build)
this is a close relative of bug #593.
> window the following command is sent to be executed:
this is slightly different, but probably a close relative of error seen in
https://trac.osgeo.org/grass/ticket/629#comment:5
> (OSGeo4W installer)
please could you try with the latest stand-alone installer?
a lot has been fixed there.
(you can have both installed without conflicts)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:1&gt;
Comment (by hamish):
probably G_convert_dirseps_to_host() is needed somewhere in the code.
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 hamish]:
Did you mean G_convert_dirseps_from_host()?
It's only necessary to convert / to \ if the path is being passed to
Windows' command interpreter. The rest of the OS understands both / and \.
OTOH, some GRASS functions only recognise /, so any \ characters need to
be converted.
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:3&gt;
Comment (by marmai):
I just tested with the latest stand-alone version (wingrass-6.4.0SVN-
r37703-1-setup.exe). Here everything works fine on my W2k system, so
probably everything is already fixed.
Thanks a lot.
Ticket URL: <http://trac.osgeo.org/grass/ticket/637#comment:4&gt;
Replying to [comment:3 glynn]:
umm, yeah.
> passed to Windows' command interpreter. The rest of the OS
Ok, so the code we need to check then is the bit that launches e.g.
dbf.exe child from lib/db/dbmi_client/start.c ???
> characters need to be converted.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 hamish]:
I don't think so. The backslashes are getting lost. Windows' command
interpreter doesn't interpret backslashes, so this looks more like Tcl's
doing. It looks like something is (implicitly or explicitly) using "eval"
or "subst" on the string, causing backslash-<char> to be replaced with
<char>.
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:6&gt;
> > e.g. dbf.exe child from lib/db/dbmi_client/start.c ???
Replying to [comment:6 glynn]:
(comment:4 of this ticket reports that fixed now)
> Windows' command interpreter doesn't interpret backslashes, so
> this looks more like Tcl's doing. It looks like something is
> (implicitly or explicitly) using "eval" or "subst" on the string,
> causing backslash-<char> to be replaced with <char>.
maybe fixed by the new `eval [list ]` stuff?
anyway I was more thinking about the ''Bad file descriptor'' problems of
unquoted spaces from https://trac.osgeo.org/grass/ticket/629#comment:5,
not the missing '\'s.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:7&gt;
Comment (by hellik):
Replying to [comment:7 hamish]:
> Hamish
WinVista 32
Grass65-svn - self-compiled today in the osgeo4w-tree
nc-dataset
i can confirm the problem
i'm not able to select a vector/raster map in the tcltk-gui, but it's
possible to enter the name for displaying the maps
helli
Ticket URL: <http://trac.osgeo.org/grass/ticket/637#comment:8&gt;
  Reporter: marmai | Owner: marisn
      Type: defect | Status: assigned
* cc: grass-dev@lists.osgeo.org (added)
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:15&gt;
sqlbuilder.py in the wxGUI now updated to safely handles spaces in the DB
path and spaces in the SQL query.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:16&gt;
Comment (by marisn):
Should be fixed in 6.4 as of r39149.
Ticket URL: <http://trac.osgeo.org/grass/ticket/637#comment:17&gt;
Replying to [comment:17 marisn]:
thanks,
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:18&gt;
tested & fixed with latest (WinGRASS-6.4.0SVN-r39271-1-Setup.exe) native
installer.
still get _spawnl error if map is not in the current mapset (both wx and
tcltk), but that's a different matter.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:19&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: Tcl Window Gui path, wingrass
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/637#comment:20&gt;
