#64: ps.map: patch to set customized scalebar units
Reporter: alf | Owner: grass-dev@lists.osgeo.org
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
The patch enhanced ps.map with two new parameters:
* scaleunits: scale units by this factor
* unitslabel: label for units
Reporter: alf | Owner: hamish
Type: enhancement | Status: assigned
Priority: minor | Milestone: 6.4.0
Resolution: | Keywords:
Changes (by hamish):
* priority: major => minor
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => hamish
* cc: grass-dev@lists.osgeo.org (added)
Comment:
The idea of adding a label to the scalebar has been on the TODO list for a
long time, thanks. (same for barscale legends; taken from 'r.support
units=')
as for scalebar units factor I wonder if we can do something more
automatic?
e.g. see nviz's or the Tcl gis.m profile tool's scale bar magic: it reads
distance units from g.proj settings, and then switches to miles from feet
or kilometers from meters when the distances passes a certain threshold.
Comment (by perk):
I made two changes to this patch. First, `background` did not
affect the units label. I fixed that. Second, I had trouble with
getting labels with like "400.000", which I suspected is
`nice_number()` trying to represent something like
"400.00000091". To fix this, I modified `nice_number()` to round the
number to 3 decimal places (the maximum it uses anyway) before it does
anything else.
I guess you need to revert locally to a pre-indentation version, see http://trac.osgeo.org/grass/wiki/HowToSVN#Revertingsubmittedchanges . Then
apply the patches, then run tools/grass_indent.sh locally and svn update
back to the current version. The patch here should remain and should be
easy to extract then.
PS: yes, a pity that it wasn't applied earlier as suggested.
Component: ps.map | Version: svn-trunk
Resolution: | Keywords: scalebar
Platform: All | Cpu: All
* keywords: => scalebar
* platform: Unspecified => All
* component: default => ps.map
* cpu: Unspecified => All
Comment:
Moritz:
> Any reason why this patch shouldn't be committed to svn ?
The need this patch scratches is real, but I have not yet been able to
dedicate the time to properly consider if it is the right approach to
solve it. see my original comment to this wish -- we can make the units
automatic like the Tcl profile tool and NVIZ's scalebar; obviously 0 to
60000m should be converted to km. I think the Tcl and NVIZ threshold rules
are pretty good and we could use them; or perhaps d.barscale's heuristic
rules. Only issue with that is if user wants miles not km (like
'd.barscale -f').
I don't like to bother users with lots of complicated controls for things
which it is reasonable for the software to do for them.
another semi-related idea is to add an option to take legend units from
the raster map's 'r.support units=' setting.
Sorry for the delay in dealing with this, my available time these days is
rather limited.
Comment (by mlennert):
things
In the case of the scalebar, I would like to keep the possibility to
decide the units by myself. It's the classical power vs usability problem,
but I think imposing units on the user is not the solution either.
Maybe a solution would be to apply the suggested patch now, leaving the
door open for a 'scaleunits auto' option or something like this...
In any case, I have attached a patch that should work with the current
grass7 trunk.
Comment (by hamish):
Replying to [comment:6 mlennert]:
> to decide the units by myself.
I agree it would be useful.
> It's the classical power vs usability problem, but I think
Right.
> leaving the door open for a 'scaleunits auto' option or
The trouble with that is that it is not nice to rescind commands
later after people have started to write scripts using the new command.
I think the solution will be to add a "units" instruction with the
default as auto. That leaves the door open for us to let this evolve at
little. Besides auto that we'd add meters, kilometers, feet,
miles, nautmiles (r.buffer opts). I do not know if it is noticeable
to bother with feet versus survey feet for a scalebar. For
correctness I suppose we should. All the GIS lib functions for that
are in place so it is not so hard to do it.
Auto would switch meters->km etc. at set breakpoints, the same as gis.m's
profile tool, nviz's scalebar, d.barscale.
> current grass7 trunk.
thanks for that. I'll try and get some work done on ps.map in the
next days.
I have now added a new "units" instruction to the ps.map scalebar.
Everything should be obvious and automatic.
You get a nice label too.
usage:
units auto|meters|kilometers|feet|miles|nautmiles
the default is auto in which case it grabs the units label from
PROJ_UNITS.
example:
# spearfish dataset
ps.map out=test.ps << EOF
raster elevation.dem
scalebar f
length 4
units nautmiles
height 0.15
where 3 7
end
grid 1852
end
end
EOF
thanks to Alessandro Frigeri for figuring out the label placement.
Type: enhancement | Status: closed
Resolution: fixed | Keywords: scalebar
(related)
I have added some code to ps.map's floating point (smooth) colortable
legend which will print a label for the map's data units if present.
Data units can be set with r.support.
I am not very happy with the x placement. The offset to the right is
currently based on the length of the tick labels and the fontsize, but as
the fonts are proportional width and the fontsize is based on the font
height, it's a bit of a fudge. It's too close for small numbers and too
far away for large numbers.
I don't know if it is possible to get the right-hand coordinate of a PS
pseudo-text box when the text is left-justified. I do not wish to right-
justify those labels.
I suppose the answer is to derive some function of max_label_length, but I
fear that will only hold for the default font=Helvetica.
Comment (by glynn):
Replying to [comment:9 hamish]:
You can use the `stringwidth` operator to obtain the width of a string
(the distance that the current point will move if you `show` the string).
If the string is short, you can obtain the bounding box with a combination
of the `charpath` and `pathbbox` operators (if the string is long,
`charpath` may overflow the maximum path length).
[comment:9 hamish]:
PS pseudo-text box when the text is left-justified. I do not wish to
right-justify those labels.
Replying to [comment:10 glynn]:
ok, thanks. I made a note of that in the source. For now I've worked out a
better placement algorithm and it seems to work ok.
I also added a few different placement options (above, to the right,
below, ..) but for now control of that is only by modifying the source
code directly.
