#640: setup.py may use different Python than configured for GRASS
Reporter: kyngchaos | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: | Platform: Unspecified
Cpu: Unspecified |
GRASS can be configured for a specific copy of Python, which could be
needed if a different version than desired is first in your PATH (maybe a
newer or experimental, incompatible version). But, when compiling vdigit
and wx nviz for the wx GUI, "python" is used, which may not be the same as
was configured. This could cause compilation problems, especially on OSX
where setup tools compilation is very particular about the
MACOSX_DEPLOYMENT_TARGET.
It looks like platform.make would need another variable to hold the python
program path, created from "python-config --prefix".
A quick fix until this is done is to temporarily add the desired python
bin to the shell PATH for the GRASS build.
Reporter: kyngchaos | Owner: grass-dev@…
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: 6.4.0 RCs
Keywords: python | Platform: Unspecified
Cpu: Unspecified |
Comment(by kyngchaos):
Well, this bug is from 4 years ago. In the current 6.4.3 RC and 7
sources, there is no setup.py that is run during make. wx nviz and vdigit
don't have compiled C code any more, so it's not needed there. I'd call
this an invalid bug now. Or fixed by coincidence.
Cpu: Unspecified |
Comment(by hamish):
ok, so the question becomes what uses Python.make, because that's
inheriting the hardcoded $(PYTHON) currently, and does it matter? if not
for the core build, then for anyone building their own addon modules, &/or
being able to specify the one you want when python 3 becomes more popular.
Cpu: Unspecified |
Ah, right.
Looks like in python.make it's just a compile command. Not an issue for
the OS X 32bit vs. 64bit problem, but important to compile for the right
version of python.
I also found $(PYTHON) in the wx gui makefile. There it's just running
python scripts to generate some files, doesn't look to me like the python
version is important.
Configuring a PYTHON could also be useful if some wx stuff is run at
compile time, to get around the 32bit OS X problem with old wxpython
versions, and on OS X wxpython python scripts need to run in pythonw...
hmm, there might already be some of those - wx-based modules that are run
to generate the help files.
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:6 hamish]:
Python.make is used by gui/wxpython, gui/scripts, scripts/r.in.wms, and
various subdirectories of lib/python.
GRASS 7 doesn't have any C or C++ code which links against the Python
library. The preferred way of integrating C and Python code is to use
ctypes to access C functions from Python.
The PYTHON make variable exists to simplify the case where the default
"python" command isn't suitable for GRASS (e.g. because it's Python 3.x,
or it doesn't have the numpy, wxPython, etc packages). In such cases, it
can be overridden on the command line, e.g. "make
PYTHON=/usr/local/bin/python2".
