[GRASS-dev] [GRASS GIS] #642: Refresh button / auto refresh button for Attribute Table viewer while using wxvdigit
wxvdigit
Reporter: stevensj | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: v.digit refresh | Platform: Unspecified
      Cpu: Unspecified |
The attribute table viewer in the wxGUI is excellent. When digitising, it
would be nice to see the new features added to the table as you create
them. Currently, to do this you have to close then reopen the attribute
table viewer.
It would be good if the attribute table could be refreshed, either
automatically when the attribute table changes, or with a refresh button
on the tab with the data view.
Ticket URL: <http://trac.osgeo.org/grass/ticket/642&gt;
wxvdigit
  Priority: normal | Milestone: 6.5.0
Resolution: | Keywords: v.digit refresh
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
* cc: martinl (added)
  * milestone: 6.4.0 => 6.5.0
Comment:
Replying to [ticket:642 stevensj]:
it would be nice to see the new features added to the table as you create
table viewer.
That's not right, you can reload attribute data from contextual menu
(right mouse button click) without closing and reopening attribute table
manager.
automatically when the attribute table chance, or with a refresh button on
See above. Your wish to refresh attribute list when digitizing (eg. adding
new feature) seems reasonable to me. I changed milestone to 6.5 since
there is no change to get this feature to 6.4.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/642#comment:1&gt;
wxvdigit
  Reporter: stevensj | Owner: martinl
      Type: enhancement | Status: assigned
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: martinl (removed)
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Replying to [comment:1 martinl]:
adding new feature) seems reasonable to me. I changed milestone to 6.5
since there is no change to get this feature to 6.4.0.
Done in r37888 (trunk) and r37889 (devbr6). Note that currently data are
reloaded (which is very time consuming task for large attribute tables).
Ideally should be added/removed only given row from the list (TODO).
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/642#comment:2&gt;
wxvdigit
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: v.digit refresh
  * status: assigned => closed
  * resolution: => fixed
Comment:
digitising, it would be nice to see the new features added to the table as
you create them. Currently, to do this you have to close then reopen the
attribute table viewer.
manager.
I added new button to ATM - to reload/refresh attribute data - see r37890
(trunk), r37891 (devbr6) and r37892 (relbr64).
Closing the ticket. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/642#comment:3&gt;
