[GRASS-dev] [GRASS GIS] #647: v.generalize's remove_small deletes wrong boundary
Reporter: hoeth | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Linux
      Cpu: x86-64 |
Running v.generalize method=remove_small on the boundaries in
"working.ascii" and "broken.ascii" yields different results, even though
the only difference between the two files is the order in which the
boundaries are stored. For "working.ascii" only the small open boundary is
removed, while for "broken.ascii" both boundaries are removed.
I observe this behaviour both in 6.3.0 and in 6.4.0RC5 (didn't try any
other releases).
Ticket URL: <http://trac.osgeo.org/grass/ticket/647&gt;
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords: v.generalize
  Platform: Linux | Cpu: x86-64
Changes (by hamish):
  * keywords: => v.generalize
  * version: unspecified => 6.4.0 RCs
  * component: default => Vector
Ticket URL: <https://trac.osgeo.org/grass/ticket/647#comment:1&gt;
Reporter: hoeth | Owner: grass-dev@…
Keywords: v.generalize | Platform: Linux
      Cpu: x86-64 |
Comment(by mmetz):
The `remove_small` method has been removed because it was faulty. Working
equivalents (that is, the original cleaning functions) are as before
provided by `v.clean`.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/647#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.generalize
Changes (by mmetz):
  * status: new => closed
  * resolution: => fixed
Comment:
`v.generalize` has been rewritten and fixed in all active branches.
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/647#comment:3&gt;
