[GRASS-dev] [GRASS GIS] #649: Nonsensical results from r.resamp.interp with certain region settings
Reporter: sorokine | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: 6.3.0
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
I am resampling a raster to higher resolution using bilinear or bicubic
methods but I am getting erroneous result.
== Steps to reproduce and more information: ==
r.info rast1
  | Type of Map: raster Number of Categories: 255
  | Data Type: FCELL
  | Rows: 128
  | Columns: 256
  | Total Cells: 32768
  | Projection: Latitude-Longitude
  | N: 89:37:40.633467N S: 90S Res: 1:24:12.036199
  | E: 179:17:48.75E W: 179:17:48.75E Res: 1:24:22.5
  | Range of data: min = 0.000000 max = 0.000000
r.region rast=rast1
g.region nsres=0.2 ewres=0.2
r.resamp.interp --o input=rast1 output=rast1resampled
rast1resampled does not look like anything close to expected.
== Workaround ==
Shove 3 degrees from the region before resampling:
g.region n=87 s=-87 w=-177 e=177
Resampled raster will be correct.
Ticket URL: <http://trac.osgeo.org/grass/ticket/649&gt;
  Priority: normal | Milestone: 6.4.0
Resolution: | Keywords: r.resamp.interp
  Platform: MacOSX | Cpu: OSX/Intel
Changes (by hamish):
  * keywords: => r.resamp.interp
  * milestone: => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/649#comment:1&gt;
