[GRASS-dev] [GRASS GIS] #65: Starting up gis.m& hangs (probably on g.region)
Reporter: pvbgis | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: 6.3.0 RCs
Keywords: |
After getting grass-6.3.0RC5 I am not able to open the GUI (gis.m&)
anymore. When looking in Windows taskmanager it appears that g.region is
the culprit. When I close the g.region process in Windows taskmanager the
GUI opens. However, when trying to display a map, it hangs again, and
again it seems to be g.region which gives the problem.
I tried to go back to grass-6.3.0RC4, but although working fine before, it
gives me the same problem now. Note that I can still open my database and
view my data layers with the Grass extension in QGIS without problems.
I am using Windows XP sp2.
Thanks
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/65&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords: wingrass
Changes (by mlennert):
  * keywords: => wingrass
* cc: grass-windows@lists.osgeo.org (added)
Comment:
I cannot reproduce this. Can you give more details about how you launch
grass ? For me both the default GUI startup and the text-based startup
plus typing gis.m work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:1&gt;
Comment (by neteler):
Paulo, can you try in the GRASS shell (or GUI):
g.region -p
? Possibly an error message pops up which helps us here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:2&gt;
  Priority: major | Milestone: 6.4.0
Changes (by neteler):
  * milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:3&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: wingrass
  * status: new => closed
  * resolution: => worksforme
Comment:
Looks like incorrectly installed GDAL. Please try with the new 6.3.0
release.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:4&gt;
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
      Type: defect | Status: reopened
  Priority: major | Milestone: 6.3.1
Changes (by pvbgis):
  * status: closed => reopened
  * resolution: worksforme =>
  * milestone: 6.4.0 => 6.3.1
Comment:
Hi Markus
Sorry for the late response.. and more sorry even to have to tell you it
still doesn't work with 6.3.0 :-(.
As an update, it hangs when starting up via the default GUI and via MSYS.
However, I can do text-base startup. The g.region -p command gives me the
region information, no problem.
However, when trying gis.m I get as far as the startup screen + output
screen before it freezes. When killing the g.region everything seems to
work fine, I can even view the region settings using the region menu, but
the trouble starts again when trying to change the region or when trying
to display a map. When killing the g.region process, the map does draw
though, but even when trying to zoom, or refresh the map, same story
again.
I got an error message once (I couldn't replicate it). What it seem to
show was the code defining a dialog:
begin_dialog{g.regoin}{
label{}
desc{manages the boundary definition for the geographic region.}
key{general}
add_flag 1{
name{d}
desc{Set from default regoin}
answer 0
label{}
quisection{existing}
add_flag2{
etc... till add_flag 12
Curiously enough (for me anyway), even when the GUI is frozen, I can still
use the g.region -p command in text-mode.
Hope this helps in some way to pin down the problem
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:5&gt;
Comment (by pvbgis):
One additional point, the g.region -p command does also work in the
MINGW32 command line screen (when in GRASS obviously). But not g.region
without the -p flag, which freeses the MINGW32 screen. In the normal
Windows command screen in GRASS, typing g.region does not seem to do
anything.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:6&gt;
Comment (by 4everskiff):
Replying to [comment:6 pvbgis]:
anything.
Hi Pauolo,
I'm trying to understand. Did you installed WinGRASS-6.3.0 using the
installer?
Did you uninstalled the previous GRASS installations before to install the
new one?
What does happen exactly when do you click on the GRASS icon on your
desktop?
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:7&gt;
- Yes, I used the WinGRASS-6.3.0 installer
- Yes, I uninstalled it and also checked if there was any file or folder
related to GRASS left on the system (there wasn't)
- I get the startup screen, after which I select the project location /
mapset and click on 'Enter Grass'. Than, the 3 screens Output-GIS.m, Map
Display 1 and GRASS.3.0 GIS Manager open, but the first two are white.
Nothing further happens, and when I click on the Gis Manager screen, I get
the 'Not Responding' message in the Title bar of that screen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:8&gt;
Replying to [comment:8 pvbgis]:
What location? demolocation?
> Than, the 3 screens Output-GIS.m, Map Display 1 and GRASS.3.0 GIS
normal
get the 'Not Responding' message in the Title bar of that screen.
not normal! it's difficult to understand what is happening...
you could try to install FileMon [1] and record the system calls, and try
to understand what is gong wrong...
[1] http://technet.microsoft.com/en-us/sysinternals/bb896642.aspx
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:9&gt;
#65: WinGRASS: Starting up gis.m & hangs (probably on g.region)
Changes (by 4everskiff):
  * version: 6.3.0 RCs => 6.3.0
  * summary: Starting up gis.m& hangs (probably on g.region) => WinGRASS:
              g.region)
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:10&gt;
  Platform: MSWindows XP | Cpu: Unspecified
  * platform: => MSWindows XP
  * cpu: => Unspecified
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:11&gt;
Maybe worthwhile mentioning, I just tried USBGIS
(http://www.archaeogeek.com/blog/portable-gis/), which includes GRASS 6.3
for Windows, and I could run GRASS without the above mentioned problems
both using the demo spearfish data set and my own GRASS database.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:12&gt;
Comment (by hamish):
does the problem persist with one of the 6.4.0rc4 installers?
Ticket URL: <https://trac.osgeo.org/grass/ticket/65#comment:13&gt;
Resolution: fixed | Keywords: wingrass
Changes (by cnielsen):
  * status: reopened => closed
  * resolution: => fixed
Comment:
On the latest
[http://grass.osgeo.org/grass64/binary/mswindows/native/WinGRASS-6.4.0SVN-
r38959-1-Setup.exe 6.4.0svn-r38959] this problem is fixed.
g.gui tcltk &
Or:
g.gui wxpython &
both work when grass is opened with the msys icons. With the cmd window
startup method, closing the GUI closes grass completely (no more terminal)
so the problem doesn't exist here either.
It may never have been fixed for the grass63 installer but it is
deprecated now anyway so I'm marking this as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/65#comment:14&gt;
