[GRASS-dev] [GRASS GIS] #657: add --with-openmp support to ./configure
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Component: Compiling | Version: svn-trunk
Keywords: openmp | Platform: All
      Cpu: All |
lib/gpde already supports OpenMP (but requires Makefile hacks to enable)
and hopefully v.lidar's tcholDec() will support OpenMP soon as well, so it
would be nice if ./configure could do checks & sets for --with-openmp as
well as --with-pthread. It would mean we have two ways of parallelizing
stuff, which is sort of redundant, but maybe each can be used to its own
strength? i.e. we have a large enough array of algorithms in the modules
so that some will be both well and poorly suited to either method.
see also http://grass.osgeo.org/wiki/OpenMP
my philosophy would be to only add it to known bottlenecks, ie fight the
urge to add it to every for loop just because it may be possible to do so.
Hit the low hanging fruit and leave the rest of the code stable.
also it would be good to add some Doxygen documentation to
lib/gis/worker.c for educational purposes.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/657&gt;
+1
I have found simple data parallelism being beneficial for satellite
imagery processing (like Landsat) even with a simple dual core.
Yann
2009/6/20 GRASS GIS <trac@osgeo.org>:
Cpu: All |
thanks,
Hamish
grass-dev mailing list
Yann Chemin
Mobile: +33 (06) 10 11 39 26
Home: +33 (02) 35 27 08 20,
Address: Gite de Mortagne,
16 rue de la chenaie,
76110 Bec de Mortagne,
France
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
+1 also from me. A useful extention to configure.
And harmless.
On Sat, Jun 20, 2009 at 2:10 PM, Yann Chemin<yann.chemin@gmail.com> wrote:
+1
Yann
Cpu: All |
thanks,
Hamish
Yann Chemin
France
Resolution: | Keywords: openmp
  Platform: All | Cpu: All
Changes (by hamish):
* cc: huhabla (added)
Comment:
wrt trunk/lib/gpde/Makefile, does -lgomp have to be before $(GMATHLIB) and
-lm or could we do
   EXTRA_LIBS += -lgomp
later?
should we do the same "+=" trick for EXTRA_CFLAGS=-fopenmp, to stop it
from clobbering any earlier setting?
hopefully when this wish is fulfilled these things could be added as
needed with a permanent ifdef in the Makefile(s). (do that centrally in
grass's libmath or in the couple of library/modules that would use it?)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:1&gt;
Comment (by hamish):
see also
http://thread.gmane.org/gmane.comp.gis.grass.devel/37962/focus=38004
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:2&gt;
Comment (by glynn):
Replying to [comment:1 hamish]:
and -lm or could we do
> later?
lib/gpde/Makefile should just have $(OMPLIB) at the appropriate place in
EXTRALIBS, probably immediately before $(MATHLIB).
EXTRA_CFLAGS = $(OMPCFLAGS)
Once the configure checks are written, Platform.make.in would define
these. Until then, you can use e.g.
make OMPCFLAGS=-fopenmp OMPLIB=-lgomp ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:3&gt;
Comment (by huhabla):
OpenMP support is implemented in the gpde and the gmath libraries. In the
gmath lib many linear equation solver and all blas level 2 and 3 functions
are parallelized with OpenMP.
OpenMP flags are compiler dependent, thus OpenMP support should be set
using C- and linker-flags bevor configure.
I.e: for gcc > 4.2:
CFLAGS="-O3 -Wall -Werror-implicit-function-declaration -fno-common
-fopenmp"
LDFLAGS="-lgomp"
This should enable OpenMP support in the libraries and ALL depending
modules.
You can test the OpenMP support when compiling the gpde and gmath tests by
hand (switch into the test directories in the lib dirs and type make). The
test library modules "test.gmath.lib" and "test.gpde.lib" should be
available in the path after starting grass.
The gmath lib test module "test.gmath.lib" provides additionally
benchmarks for blas level 2 and 3 functions and for many solver.
gmath/test> test.gmath.lib help
Description:
  Performs benchmarks, unit and integration tests for the gmath library
Usage:
  test.gmath.lib [-uia] [unit=string] [integration=string] [rows=value]
    [solverbench=string] [blasbench=string] [--verbose] [--quiet]
Flags:
   -u Run all unit tests
   -i Run all integration tests
   -a Run all unit and integration tests
  --v Verbose module output
  --q Quiet module output
Parameters:
          unit Choose the unit tests to run
                 options: blas1,blas2,blas3,solver,ccmath,matconv
   integration Choose the integration tests to run
                 options:
          rows The size of the matrices and vectors for benchmarking
                 default: 1000
   solverbench Choose solver benchmark
                 options: krylov,direct
     blasbench Choose blas benchmark
                 options: blas2,blas3
I.e testing the speedup of the blas level 2 and 3 functions of the latest
svn trunk of grass7, compiled with the flags mentioned above on a 8 core
intel xeon system:
gmath/test> setenv OMP_NUM_THREADS 1
gmath/test> test.gmath.lib blasbench=blas2 rows=5000
++ Running blas level 2 benchmark ++
Computation time G_math_Ax_sparse: 0.244123
Computation time G_math_Ax_sband: 0.280636
Computation time G_math_d_Ax: 0.134494
Computation time G_math_d_Ax_by: 0.18556
Computation time G_math_d_x_dyad: 0.268684
-- gmath lib tests finished successfully --
gmath/test> setenv OMP_NUM_THREADS 4
Computation time G_math_Ax_sparse: 0.072549
Computation time G_math_Ax_sband: 0.192712
Computation time G_math_d_Ax: 0.036652
Computation time G_math_d_Ax_by: 0.047904
Computation time G_math_d_x_dyad: 0.080534
gmath/test> test.gmath.lib blasbench=blas3 rows=1000
++ Running blas level 3 benchmark ++
Computation time G_math_d_aA_B: 0.013263
^[[AComputation time G_math_d_AB: 18.729
Computation time G_math_d_aA_B: 0.006946
Computation time G_math_d_AB: 4.80446
The gmath library should work fine with OpenMP support. In the gpde
library is still a bug (race condition) in the linear equation system
creator.
Ticket URL: <http://trac.osgeo.org/grass/ticket/657#comment:4&gt;
Reporter: hamish | Owner: grass-dev@…
      Cpu: All |
Comment(by hamish):
patch attached for review.
missing from it, but done locally: autoconf'd ./configure (too big), added
$(OMPLIBPATH) to Grass.make, added $(OMP..) to lib/gmath/test and
lib/gpde/test Makefiles.
missing from it, and TODO (pls help): only set OMPCFLAGS=-fopenmp for gcc
>= 4.2.1
seems to work very nicely indeed. race condition for lib/gpde mentioned in
comment:4 still exists.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:5&gt;
      Cpu: All |
Comment(by hamish):
added in trunk with r49652 with support for: gcc (>=4.2.1), Intel's C
compiler, AMD's x86 Open64 compiler, and PGI's compiler. Additional
support for Solaris cc, AIX xlc, and SGI IRIX 6.5 MIPSpro C is known but
left commented out for now.
todo:
# try to build a test program with "$CC $OMPCLFAGS" to confirm it works
#...how?
#echo "int main() {return 0;}" > test.c
#$CC $OMPCLFAGS test.c -o test
I think the test compile is better than explicitly checking the gcc
version,
GCC_VERSION=`${CC} -dumpversion`
GCC_VERSION_MAJOR=$(echo $GCC_VERSION | cut -d'.' -f1)
GCC_VERSION_MINOR=$(echo $GCC_VERSION | cut -d'.' -f2)
GCC_VERSION_PATCH=$(echo $GCC_VERSION | cut -d'.' -f3)
for a gcc version test, see also:
  http://git.savannah.gnu.org/gitweb/?p=autoconf-
archive.git;a=blob_plain;f=m4/ax_gcc_version.m4
a positive but reasonably inefficient speedup for v.surf.rst has been
added in r49653.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:6&gt;
      Cpu: All |
Comment(by martinl):
Still relevant?, there is `--with-openmp` available in `configure` script.
Ticket URL: <http://trac.osgeo.org/grass/ticket/657#comment:7&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: openmp
  * status: new => closed
  * resolution: => fixed
Comment:
yes, it's done in the configure script, which is all for this ticket. the
wider subject of using OpenMP well is an ongoing project.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/657#comment:8&gt;
