[GRASS-dev] [GRASS GIS] #659: probable memory leak in v.surf.bspline
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.surf.bspline | Platform: All
      Cpu: All |
source:grass/trunk/vector/lidar/v.surf.bspline/main.c@#L364 has:
nrows = G_window_rows();
ncols = G_window_cols();
if (!G_alloc_matrix(nrows, ncols))
     G_fatal_error(_("Interpolation: The region resolution is too high: "
                    "%d cells. Consider to change it."), nrows * ncols);
is that a rather big memory leak? should it be like:
raster_matrix = G_alloc_matrix(nrows, ncols);
if (!raster_matrix)
     G_fatal_error(...);
else
     G_free_matrix(raster_matrix);
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/659&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.surf.bspline
  Platform: All | Cpu: All
Changes (by mmetz):
  * status: new => closed
  * resolution: => fixed
Comment:
Right, raster_matrix was allocated twice for some obscure reason. Fixed in
all branches with the recent overhaul of the lidar tools.
Ticket URL: <https://trac.osgeo.org/grass/ticket/659#comment:1&gt;
      Type: defect | Status: closed Priority: normal | Milestone: 6.4.0 Component: Vector | Version: 6.4.0 RCs Resolution: fixed | Keywords: v.surf.bspline Platform: All | Cpu: All ---------------------+------------------------------------------------------
Changes (by mmetz):
Comment:
BTW, fixed are also all the other memory leaks in some other lidar tools when accessing the auxiliary table (db_free_string() was missing).
