[GRASS-dev] [GRASS GIS] #664: All vector geometry deleted after editing with v.edit
Reporter: epatton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
I really hope there is a simple explanation for this one...otherwise this
is a serious bug. I was running v.edit from the terminal on a polygon
vector in 6.5svn. I was trying to break two specific boundaries in order
to merge them in another v.edit run. Here is the output from 'v.edit
tool=break' (ids were obtained from interactive querying):
v.edit map=Bonavista_Waterbodies_clipped type=line,boundary tool=break
ids=2599,2618 --v
Selecting features...
2 of 3568 features selected from vector map
<Bonavista_Waterbodies_clipped@PERMANENT>
  100%
Intersections: 0
Intersections: 0
0 lines broken
Building topology for vector map <Bonavista_Waterbodies_clipped>...
Registering primitives...
3568 primitives registered
88380 vertices registered
Building areas...
  100%
2475 areas built
2440 isles built
Attaching islands...
  100%
Attaching centroids...
  100%
Topology was built
Number of nodes: 3533
Number of primitives: 3568
Number of points: 0
Number of lines: 0
Number of boundaries: 2626
Number of centroids: 942
Number of areas: 2475
Number of isles: 2440
Number of areas without centroid: 1533
v.edit complete.
Next, I ran v.edit tool=merge, trying to merge two side-by-side boundaries
that virtually overlap one another:
v.edit map=Bonavista_Waterbodies_clipped type=line,boundary tool=merge
ids=2599,2618 --v
  100%
2 lines merged
0 primitives registered
Building areas...
0 areas built
0 isles built
Topology was built
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.edit complete.
All vector geometry has been deleted! I have zoomed to full extent, I have
exited Grass and tried re-displaying the vector, nothing. v.info confirms
there is nothing in this vector:
v.info -t Bonavista_Waterbodies_clipped
nodes=0
points=0
lines=0
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
primitives=0
map3d=0
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/664&gt;
  Reporter: epatton | Owner: martinl
      Type: defect | Status: assigned
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Comment:
Please can you reproduce this behaviour in NC dataset?
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:1&gt;
Comment (by epatton):
No, I can't. I tried editing a few vectors in the NC location and things
seem ok, although I only had time to try for about 15 minutes.
Fortunately, all is not lost; I can return to an intermediate vector
dataset and resume my edits, but it is still frustrating. I'll try and
takes notes on what happens the next time around.
~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 epatton]:
In this case can you send me sample location and exact commands?
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:3&gt;
Resolution: | Keywords: v.edit
  * keywords: => v.edit
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:4&gt;
  Priority: major | Milestone: 6.5.0
  * priority: critical => major
Comment:
Replying to [comment:3 martinl]:
things seem ok, although I only had time to try for about 15 minutes.
Downgrading priority.
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:5&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: v.edit
  * status: assigned => closed
  * resolution: => invalid
Comment:
Closed, please re-open if needed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/664#comment:6&gt;
