GDAL
February 23, 2008, 6:01pm
1
#67: r.out.gdal type= and no-data issues
Reporter: sieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.3.0
Component: default | Version: unspecified
Keywords: |
If data 'type' is not specified and the input raster has nulls, r.out.gdal
picks a correct datatype automatically, but sets a bogus no-data value.
Example, in spearfish60:
r.out.gdal in=geology out=gelogy.tif
Exporting to GDAL data type: Byte
100%
WARNING: Input raster map constains cells with NULL-value (no-data). For
no-data values was used value -2147483648. You can specify nodata
value by nodata parameter.
r.out.gdal complete.
Note the bogus -2147483648 no-data value, not in Byte datatype range.
If the user specifies 'type=Byte' explicitely, r.out.gdal sets nodata to
255 by default (OK):
GRASS 6.3.svn (spearfish60):~ > r.out.gdal in=geology out=gelogy2.tif
type=Byte
100%
no-data values was used value 255. You can specify nodata value
by
nodata parameter.
Ticket URL: <http://trac.osgeo.org/grass/ticket/67> ;
GRASS GIS <http://grass.osgeo.org >
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
GDAL
February 23, 2008, 6:44pm
2
Reporter: sieczka | Owner: martinl
Type: defect | Status: assigned
Resolution: | Keywords: gdal
Changes (by martinl):
* keywords: => gdal
* status: new => assigned
* owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Please test the attached patch. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/67#comment:1> ;
GDAL
February 24, 2008, 9:20pm
3
Changes (by neteler):
* cc: warmerdam (added)
Comment:
I darkly remember that GDAL uses out-of-range values for no data.
Possible?
See also
http://lists.osgeo.org/pipermail/grass-dev/2007-May/031316.html
http://lists.osgeo.org/pipermail/grass-dev/2007-May/031715.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/67#comment:2> ;
GDAL
February 29, 2008, 2:50pm
4
Comment (by martinl):
Replying to [comment:2 neteler]:
Possible?
> See also
this should be already fixed, see r29555.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/67#comment:3> ;
GDAL
March 3, 2008, 8:30am
5
Replying to [comment:1 martinl]:
Patch applied in trunk, r30433. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/67#comment:4> ;
GDAL
March 9, 2008, 4:22pm
6
Type: defect | Status: closed
Resolution: fixed | Keywords: gdal
* status: assigned => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/67#comment:5> ;
