GDAL
February 26, 2008, 12:22pm
1
#68: grass libraries sonames
Reporter: wrobell | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.0
Component: default | Version: 6.3.0 RCs
Keywords: |
grass build system does not set sonames of libraries. it causes problems
while packaging grass using i.e. rpm which uses sonames for dependencies.
link to the patch
http://cvs.pld-linux.org/cgi-bin/cvsweb.cgi/SOURCES/grass-soname.patch
the patch was created by Jakub Bogusz (qboosh at pld-linux dot org)
and updated by me for grass 6.3.0RC5.
Ticket URL: <http://trac.osgeo.org/grass/ticket/68> ;
GRASS GIS <http://grass.osgeo.org >
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
GDAL
February 26, 2008, 3:41pm
2
Resolution: | Keywords:
Comment (by glynn):
Replying to [ticket:68 wrobell]:
dependencies.
> link to the patch
GRASS is supposed to compile on platforms other than Linux, so hard-coding
platform-specific linker switches is bogus.
The correct way to fix this is to modify the "Linux" portion of the
SC_CONFIG_CFLAGS macro in aclocal.m4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/68#comment:1> ;
GDAL
April 24, 2008, 1:06pm
3
Priority: minor | Milestone: 6.4.0
Changes (by neteler):
* milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/68#comment:2> ;
GDAL
May 2, 2013, 1:41am
4
Reporter: wrobell | Owner: grass-dev@…
Component: Packaging | Version: 6.3.0 RCs
Keywords: soname | Platform: Linux
Cpu: All |
Changes (by hamish):
* keywords: => soname
* platform: => Linux
* component: Default => Packaging
* cpu: => All
Comment:
status?
Ticket URL: <https://trac.osgeo.org/grass/ticket/68#comment:3> ;
