[GRASS-dev] [GRASS GIS] #684: g.extension: default url should not point to grass7
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: default | Version: 6.4.0 RCs
Keywords: g.extension | Platform: Unspecified
      Cpu: Unspecified |
g.extension proposes the following default URL for downloading AddOns:
https://svn.osgeo.org/grass/grass-addons/grass7
However, most AddOns are in
Shouldn't the default rather point there ?
This then also raises the question whether having a separate grass7
directory in that tree is really useful. Shouldn't AddOns just declare in
README's that they are only usable in a specific grass version ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/684&gt;
Component: default | Version: svn-trunk
Resolution: | Keywords: g.extension
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * version: 6.4.0 RCs => svn-trunk
  * milestone: 6.5.0 => 7.0.0
Comment:
Replying to [ticket:684 mlennert]:
I think that g.extension from trunk should point to GRASS 7 compatibile
modules.
Another options would to provide patch for GRASS7. E.g. g.extension could
check if dictionary contains {{{grass7.diff}}} and patch the source code
before compilation.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/684#comment:1&gt;
Comment (by mlennert):
Replying to [comment:1 martinl]:
modules.
Aren't most modules in the main directory also GRASS 7 compatible ? What
defines this compatibility ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/684#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 mlennert]:
compatibile modules.
I don't think so, C/C++ modules needs to be updated to use rasterlib.
Shell script modules need to be rewritten to Python (not obligatory, but
wanted).
Ticket URL: <http://trac.osgeo.org/grass/ticket/684#comment:3&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: g.extension
Changes (by mlennert):
  * status: new => closed
  * resolution: => invalid
Comment:
Replying to [comment:3 martinl]:
What defines this compatibility ?
wanted).
Ok, in light of this I'm closing bug as invalid.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/684#comment:4&gt;
Comment (by hamish):
I wonder for cases where it is known that the (e.g. C vector) module needs
no porting changes if it is possible to symlink the module dir into the
grass7 addons svn?
Perhaps something with 'svn add' + 'svn:special'.
  http://subversion.tigris.org/faq.html#symlinks
The idea is to avoid the double effort of keeping the two "branches" in
sync.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:5&gt;
Replying to [comment:5 hamish]:
needs no porting changes if it is possible to symlink the module dir into
the grass7 addons svn?
At least you need to replace
#include <grass/Vect.h>
by
#include <grass/vector.h>
sync.
Patch again trunk could avoid it.
Martin
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:6&gt;
Replying to [comment:6 martinl]:
Ops, typo, I meant a patch which enables compiling against trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:7&gt;
> could check if dictionary contains {{{grass7.diff}}} and patch the
> source code before compilation.
FWIW I have and do use a similar approach in a few other projects. (mostly
debian packaging patches to allow things to also work on ubuntu, 64bit
versions, etc)
All in all I have not enjoyed the experience, I have found it quite
painful to maintain/rebuild the patch sets every time a change is applied
in trunk.
but YMMV and I may well be going about it the hard way.
2c,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/684#comment:8&gt;
