#686: wxgui: georectify need to set region in XY location to extension of map to
be able to see it
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: wxgui georectify | Platform: Unspecified
Cpu: Unspecified |
- import a non-georeferenced image into unprojected xy-location
- set region to n=1 s=0 w=0 e=1
- enter projected location
- launch georectify
-> the map is not visible and the button "zoom to selected map does not
work"
To be able to see the map, you have to adjust the computational region of
the xy-location to the extension of the map.
be able to see it
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: wxgui georectify
Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
be able to see it
Comment (by mlennert):
Replying to [ticket:686 mlennert]:
work"
To complement this, here's the traceback (possibly better to open a new
ticket for this):
File "/home/mlennert/SRC/GRASS/grass64_release/dist.i486
-pc-linux-gnu/etc/wxpython/gui_modules/toolbars.py", line
361, in OnZoomMap
self.mapdisplay.MapWindow.ZoomToMap(layer=layer)
-pc-linux-gnu/etc/wxpython/gui_modules/mapdisp.py", line
2359, in ZoomToMap
for l in layer:
TypeError
'MapLayer' object is not iterable
be able to see it
Comment (by cmbarton):
be able to see it
Replying to [comment:3 cmbarton]:
> I think this is fixed. Can someone confirm?
Nope, I still see the same problem in 6.5svn. Did you fix it there ?
be able to see it
be able to see it
be able to see it
Type: defect | Status: closed
Resolution: fixed | Keywords: wxgui georectify
Changes (by cmbarton):
be able to see it
Type: defect | Status: reopened
Changes (by neteler):
be able to see it
I just fixed it in r41307. This is a 6.4 issue.
The code in 6.5 and 7 is completely different. I'm checking it there too.
be able to see it
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
be able to see it
I just tested this and it appears to be already fixed in 6.5 and 7.0 (at
r41307 for both versions). Could you please test in another platform?
