[GRASS-dev] [GRASS GIS] #692: computational region in grasswxpy.po file
Reporter: lucadelu | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: computational po | Platform: Unspecified
      Cpu: Unspecified |
I don't understand what "computational region" means in grasswxpy.po file,
there are a lot of string with "computational region" like "Zoom to
computational region (set with g.region)" or "Set computational region
from selected map(s)"
Luca
Ticket URL: <http://trac.osgeo.org/grass/ticket/692&gt;
Component: Translations | Version: svn-trunk
Resolution: | Keywords: computational po
  Platform: All | Cpu: All
Changes (by neteler):
  * platform: Unspecified => All
  * component: default => Translations
  * cpu: Unspecified => All
Comment:
I don't understand "computational region" either - can we reduce it to
region? Or: I assume that perhaps "current region" was meant? I have a
script to search-replace this in all files once we agree how that should
be called.
Ticket URL: <http://trac.osgeo.org/grass/ticket/692#comment:1&gt;
Comment (by martinl):
Replying to [comment:1 neteler]:
be called.
AFAIK the initial idea was to distinguish display region (what is
displayed in the map window) and the region where is done raster
computation (e.g. by r.mapcalc). From this POV is "computation region"
quite informative term to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/692#comment:2&gt;
Comment (by hamish):
Replying to [comment:2 martinl]:
> is displayed in the map window) and the region where is done
> raster computation (e.g. by r.mapcalc).
Correct.
> From this POV is "computation region" quite informative term to
> me.
As long as we have both a display window and g.region settings for raster
*and* vector etc. (v.in.region, v.in.ascii -r, ps.map, g.region -n, ...),
we will need some vocabulary to distinguish between the two.
fwiw I borrowed the term from the SWAN model (GPL).
  http://www.swan.tudelft.nl
  http://vlm089.citg.tudelft.nl/swan/online_doc/swanuse/node24.html
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/692#comment:3&gt;
Comment (by neteler):
Replying to [comment:3 hamish]:
raster *and* vector etc. (v.in.region, v.in.ascii -r, ps.map, g.region -n,
...), we will need some vocabulary to distinguish between the two.
The underlying question is how to translate the currently chosen term
(into other languages like Italian).
Ticket URL: <https://trac.osgeo.org/grass/ticket/692#comment:4&gt;
Comment (by mmetz):
If I remember right, this term in the GUI evolved from "current region" to
"current computational region" (GUI of early grass6 versions) to
"computational region".
g.region and all modules use "current region"; it would help to avoid
confusion if the same term is used throughout for the same thing. Terms
for the different regions (or windows) are defined in the manual of
g.region. So I would vote for either "current region" or "computational
region" but not the one in module man pages and the other in the GUI.
Just my 2c,
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/692#comment:5&gt;
Replying to [comment:5 mmetz]:
> to avoid confusion if the same term is used throughout for
> the same thing. Terms for the different regions (or windows)
> are defined in the manual of g.region. So I would vote for
> either "current region" or "computational region" but not
The dichotomy, and so the need for modifying distinctions, is only present
from the GUI. Adding redundant modifiers into the back-end modules just
adds to the confusion IMO. I am all for improved clarity and consistency,
but am wary that it is very easy to go over the top on such crusades.
(here using the term for the child to describe the parent)
Replying to [comment:5 neteler]:
> chosen term (into other languages like Italian).
Hopefully this discussion better elucidates what the perhaps imperfect
english wording is trying to say?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/692#comment:6&gt;
Comment (by mmetz):
Replying to [comment:6 hamish]:
present from the GUI. Adding redundant modifiers into the back-end modules
just adds to the confusion IMO. I am all for improved clarity and
consistency, but am wary that it is very easy to go over the top on such
crusades.
OK. I guess there will always be some confusion with all the different
regions when displaying a raster map (default region, current
computational region, current display region, the raster's region). In
cases like this ticket, a short citation from the wxGUI manual may clarify
the meaning. It would be nice if the wording is clear without reading too
many manuals (don't say RTFM too often). Unfortunately this needs to be
sorted out for every language separately.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/692#comment:7&gt;
