[GRASS-dev] [GRASS GIS] #694: Add point option as input for v.overlay
Reporter: voncasec | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: All
      Cpu: All |
Currently with v.overlay, we can only use operators (and,or,not,xor) for
extracting lines or polygons from feature A given feature area B. It would
be nice to expand this option to include points as a possible Feature A
class.
Currently, If I wanted to select all points that do not fall within a
given polygon, I would first have to create a vector area for the given
region (v.in.region), then I would have to run v.overlay using the 'not'
operator to create an area feature that excludes the polygons of interest,
than I would run v.select to select the points that fall within the new
polygon.
Ticket URL: <http://trac.osgeo.org/grass/ticket/694&gt;
  Priority: normal | Milestone: 6.5.0
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by hamish):
  * milestone: 6.4.0 => 6.5.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/694#comment:1&gt;
