#696: "g.region -dp" doesn't work
Reporter: tamura1105 | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: g.region -dp | Platform: MSWindows XP
Cpu: x86-64 |
"g.region -dp" command causes the following error message:[[BR]]
*************************************************[[BR]]
ERROR: region for current mapset is invalid[[BR]]
<projection field missing>[[BR]]
run "g.region"[[BR]]
And the contents of WIND file has been truncated as follows:[[BR]]
proj: 99[[BR]]
zone: 0[[BR]]
And the contents of the WIND file has been truncated as follows:[[BR]]
proj: 99[[BR]]
zone: 0[[BR]]
Mapset: PERMANENT or user1
