[GRASS-dev] GRASS GIS 7.0.1 planning: potential backports
I have been trying to track potential backports:
* v.in.ogr: backport island recognition message (sync geom.c, main.c
and v.in.ogr.html)
* v.select: code optimization, no bug fix
* r64993 - grass/trunk/gui/wxpython/vnet - Author: turek Date: 2015-04-06
* r64979 - grass/trunk/gui/wxpython/vnet - Author: turek Date: 2015-04-02
* r64898 - grass/trunk/scripts/r.unpack - Author: lucadelu Date: 2015-03-24
* r64895 - grass/trunk/raster/r.li: . r.li.daemon - Author: wenzeslaus
Date: 2015-03-23
* r64854 - grass/trunk/gui/wxpython/lmgr - Author: wenzeslaus Date: 2015-03-14
* r64783 - grass/trunk/vector/v.vol.rst - Author: annakrat Date: 2015-03-02
* r64630 - grass/trunk/vector/v.net - Author: neteler Date: 2015-02-14
* r64470 - grass/trunk/lib/python/temporal - Author: huhabla Date: 2015-02-05
* r64226 - grass/trunk: gui/xml lib/gis - Author: glynn Date: 2015-01-16
* r63543 - grass/trunk/lib/btree2 - Author: mmetz Date: 2014-12-14
* r63378 - grass/trunk/raster/r.in.gdal - Author: mmetz Date: 2014-12-05
* r63374 - grass/trunk/lib/init - Author: martinl Date: 2014-12-05
* r63369 - grass/trunk/lib/python/docs/src - Author: wenzeslaus Date: 2014-12-04
* r63361 - grass/trunk/lib/display - Author: glynn Date: 2014-12-03
* r63308 - grass/trunk/lib/gis - Author: mmetz Date: 2014-11-30
* r63238 - grass/trunk: db/drivers/sqlite scripts/v.db.update -
Author: neteler Date: 2014-11-28
* r63194 - grass/trunk/scripts/i.tasscap - Author: neteler Date: 2014-11-27
* r62026 - grass/trunk: display/d.info include/defs lib/display -
neteler Date: 2014-09-17
* r63077 - grass/trunk/gui/wxpython/vdigit - Author: mmetz Date: 2014-11-26
* r62904 - grass/trunk/lib/gis - Author: martinl Date: 2014-11-25
* r62850 - grass/trunk/general/g.parser - Author: glynn Date: 2014-11-21
* r62828 - grass/trunk: display/d.his raster/r.his - Author:
wenzeslaus Date: 2014-11-19
* r62776 - grass/trunk/lib/gis - Author: mmetz Date: 2014-11-17
* r62756 - grass/trunk/lib/gis - Author: martinl Date: 2014-11-16
* r62709 - grass/trunk/lib/python/script - Author: wenzeslaus Date: 2014-11-11
This list is incomplete, especially concerning the wxGUI and PyGRASS.
Also tracked here:
https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.1tobebackported
Please check, backport where reasonable and delete from the trac Wiki list.
We should consider to prepare 7.0.1 in a some weeks time.
thanks
On Tue, Apr 7, 2015 at 2:36 PM, Markus Neteler <neteler@osgeo.org> wrote:
The respective authors: please check, backport where reasonable and
2015-04-07 14:36 GMT+02:00 Markus Neteler <neteler@osgeo.org>:-05
with respect to bugfix-only backports, this is a new feature
* r62904 - lib/gis - Author: martinl Date: 2014-11-25
Candidates for backport (putting them to my TODO list)
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
let's get 7.0.1RC1 out soon...! But...
... please go through the list.
thanks
2015-06-04 20:55 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I tried to cleanup the list, what I cannot judge is (by authors):
mmetz:
https://trac.osgeo.org/grass/changeset/62091 (I would say no for
backport, no bug-fix, 2 cents)
https://trac.osgeo.org/grass/changeset/63543 (probably harmless)
https://trac.osgeo.org/grass/changeset/63378 (bug-fix, probably should
be backported)
https://trac.osgeo.org/grass/changeset/63308 (probably no, it's not bug-fix)
https://trac.osgeo.org/grass/changeset/63077 (probably yes)
https://trac.osgeo.org/grass/changeset/62776 (probably no, it's not bug-fix)
glynn:
https://trac.osgeo.org/grass/changeset/64834 (no idea)
https://trac.osgeo.org/grass/changeset/64226 (probably no, it's not bug-fix)
https://trac.osgeo.org/grass/changeset/63361 (I would say no, heavy
changes in trunk)
https://trac.osgeo.org/grass/changeset/62026 (probably no, it's not bug-fix?)
https://trac.osgeo.org/grass/changeset/62850 (no idea, probably not)
lucadelu:
https://trac.osgeo.org/grass/changeset/64898 (no idea)
huhabla:
https://trac.osgeo.org/grass/changeset/64470 (probably yes?)
neteler:
https://trac.osgeo.org/grass/changeset/63238 (probably no, it's not bug-fix)
I can do backports when I receive any feedback. These backports are
long-standing issue (since beginning of April). My suggestion is to
mark RC1 tomorrow if possible...
Thanks for collaboration! Martin
Martin Landa
On Fri, Jun 5, 2015 at 4:17 PM, Martin Landa <landa.martin@gmail.com> wrote:
The updated list is now way shorter. I went through a lot of commits
locally flagged as "backport" in my inbox and also checked those on
above list.
AFAIK remain now:
r65343 - vector/v.random/main.c: martinl Date: 2015-05-31
r62091 - vector/v.select: speed up OP_OVERLAP - Author: mmetz 2014-09-26
r64834 - lib/python/script/core.py - Author: glynn Date: 2015-03-11
(Attempt to fix gettext behaviour (issue #2617))
above list.
AFAIK remain now:
I don't see how this can create any problems, and it does solve the one of having a link to a non-existing table, so I would say +1 for backport.
I've only tested this very briefly, but results seem identical and the speedup is very significant, so I would plead for backport, but MarkusM should have the last word on this.
No idea on this particular fix, but I have the feeling that the whole encoding handling could need a serious overall reflection with a clear definition of coding rules. AFAIU, at this stage we have different "solutions" across the code and that none are really satisfactory, especially as none is really implemented in a global and unified way.
Moritz
On Mon, Jun 8, 2015 at 8:51 AM, Moritz Lennert
wrote:
above list.
AFAIK remain now:
+1 also here
.. I just locally backported, it also needs
https://trac.osgeo.org/grass/changeset/62045
Agreed.
Ah, this does look quite heavy, indeed. Has anyone else had time to test ?
No news from MarkusM ?
Moritz
On Mon, Jun 8, 2015 at 3:05 PM, Moritz Lennert
Yes, I am testing (and it has been in place since Sept 2014).
Here the comparison, in GRASS 7.0.1svn (nc_spm_08_grass7):~ >
# old version:
v.buffer input=railroads output=railroads_buf20m distance=20
time -p v.select ainput=zipcodes_wake binput=railroads_buf20m
output=zipcodes_wake_railroads operator=overlap
v.select complete. 171 features written to output.
real 125.23
user 82.05
sys 42.61
# new version
real 6.72
user 4.42
sys 2.03
6.72/125.23 = 0.05366126
It is *quite* faster!
No.
markusN
Backported as r65423.
Remains for RC1:
r64404 - libpython: move cmd list <-> tuple from wxGUI: martinl Date:
Feb 2, 2015
r64834 - lib/python/script/core.py: fix gettext behaviour - Author:
2015-06-08 14:27 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
AFAIK remain now:
+1 also here
backported 65424. Martin
Martin Landa
2015-06-08 23:37 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Feb 2, 2015
then we should also backport r64406 and probably others, it's seems to
me that it's not necessary to backport these changes.
Martin
Martin Landa
On Mon, Jun 8, 2015 at 11:50 PM, Martin Landa <landa.martin@gmail.com> wrote:
Feb 2, 2015
ok - I cannot judge and GUI is always a weak thing with all the Python
portability issues...
I earlier just skimmed through my list of flagged commits.
2015-06-08 23:52 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
my suggestion is to backport it immediately after we release 7.0.1
[1], to have time to do more tests. I will do it. Martin
[1] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.2tobebackported
Martin Landa
What is the status of r65057, #2626, and #2655?
In 70 release branch, I’m not able to use PostgreSQL attribute table but it works in trunk. I think that this is thanks to r65057. The bug was probably also reason for encountering #2626.
Vaclav
db.login + pg & mysql driver: support hostname and port
https://trac.osgeo.org/grass/changeset/65057
v.out.ogr does not suggest db.connect and db.login when not set
http://trac.osgeo.org/grass/ticket/2626
update t.connect to use db.login host= port=
https://trac.osgeo.org/grass/ticket/2655
[GRASS-dev] [GRASS-SVN] r65057 - in grass/trunk/db: db.login drivers/mysql drivers/postgres
http://lists.osgeo.org/pipermail/grass-commit/2015-April/035962.html
http://lists.osgeo.org/pipermail/grass-dev/2015-April/074808.html
I have added it to
It would be important to get RC1 asap out.
In 70 release branch, I'm not able to use PostgreSQL attribute table but it
Vaclav
drivers/postgres
2015-06-12 16:14 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I have added it to
it's not critical, I moved this task to 7.0.2.
+1^n
Ma
Martin Landa
On Tue, Jun 9, 2015 at 10:21 PM, Vaclav Petras &lt;
wenzeslaus@
I have added it to
for r65440 in #2448 needs testing on Windows
see https://trac.osgeo.org/grass/ticket/2448#comment:23
tested locally here in a simple windows command line (outside any winGRASS
session, not in a OSGeo4W-command line):
C:\Users\xxxx>set GISBASE=C:\OSGeo4W_use\apps\grass\grass-7.0.0
C:\Users\xxxx>set
FREETYPEBASE=C:\OSGeo4W_use\bin;C:\OSGeo4W_use\apps\msys\bin;C:\OSGeo4W_use\apps\grass\grass-7.0.0\lib
C:\Users\xxxx>set PATH=%FREETYPEBASE%;%PATH%
C:\Users\xxxx>set GISRC=dummy
C:\Users\xxxx>"%GISBASE%\bin\g.mkfontcap.exe" -o
it works.
+1 for backporting
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-GIS-7-0-1-planning-potential-backports-tp5200227p5210721.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
2015-06-12 23:14 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
there is still r64834 to marked for backport [1]. Does anybody here
option about that?
Thanks Martin
[1] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.1tobebackported
Martin Landa
