r.stream.basins: Calculates surface roughness in a moving-window, as the
orientation of vectors normal to surface planes.
r.stream.channel: Generates a smooth approximation of the input raster and a
discontinuity map.
r.stream.distance: Creates shades from various directions and combines then
into RGB composition.
r.stream.order: A model for shallow landslide susceptibility.
r.stream.segment: Computes Sky-View Factor visualization technique
v.in.geopaparazzi: Computes the best-fitting ellipse for given vector data.
v.in.gns: Links all OGR layers available in given OGR datasource.
v.in.gps: segment points along a vector line with fixed distances
v.in.ply: Lithospheric flexure: gridded deflections from scattered point
loads
v.in.proj: Calculates DEM derived characteristics of habitats.
v.in.wfs2: Creates metadata based on ISO standard for specified vector map.
v.isochrones: Imports data from Geopaparazzi database.
The incomplete manual pages of r.green*.html are breaking the script
which creates the overview.
I spent already lot of time to work around that but have no more time for that.
Perhaps there could be script and page which would show the guilty modules. There are already pages about build of the module. Perhaps there is a way to extent it or clone it to check for (some) submitting rules. There is a script to do static source code analysis for Python code:
