[GRASS-dev] [GRASS GIS] #70: imagery modules: strip @mapset part
  Reporter: hamish | Owner: grass-dev@…
      Type: task | Status: new
  Priority: major | Milestone: 8.0.0
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: imagery
Changes (by marisn):
* platform: => Unspecified
* milestone: 6.4.6 => 8.0.0
* component: Default => Imagery
* cpu: => Unspecified
* type: defect => task
Comment:
GRASS 7.8.0 will contain code allowing i.group to list content of groups
in other mapsets. It also handles correctly creation of groups with maps
from other mapsets (fully qualified map names). It was implemented in
r73633 and r74107. See also: #3491
Still other imagery modules are working according to initial design –
groups are useable only in the current mapset. Thus a new design should be
proposed and modules changed to fit the new approach. I am not certain if
such invasive changes should be done in GRASS 7.
One of options would be to handle groups like raster colours – in each
mapset an override (shadowing) could be implemented. If a module requests
write option to group, files are written into current mapset and thus
changes are visible only in the current mapset. Downside – changes are
accessible only from current mapset – it could be problematical for sig
files.
Other approach would be to take signature files and classification results
out from groups completely. There would be no big change in not writing
classification output to group. With signature files it is more tricky, as
new functions handling sig files then should be introduced or sig file
handling should be shifted to the user (output to specified path/file
instead of current mapset).
Ticket URL: <https://trac.osgeo.org/grass/ticket/70#comment:23&gt;
