[GRASS-dev] [GRASS GIS] #702: nviz: points with attributes broken
Reporter: helena | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: NVIZ | Version: 6.4.0 RCs
Keywords: | Platform: All
      Cpu: All |
NVIZ visualization of points with attributes in GRASS65
(tested on RH linux, compiled from source) and in GRASS64 on MSWindows -
(the latest stand alone installer) and GRASS64 Mac installer appears to be
broken.
I tried with nc_spm schools_wake (attributes capacity, mobile units)
and firestations (pumps) and for color the rendered color is black,
although some points are colored, but it is a different color than the one
given in the GUI.
Size turns to flat, both for Auto and for various values of custom.
It looks like scaling between the actual values > classes > size or
color does not work properly.
It works in GRASS63 - what has changed? Maybe the modifications in NVIZ
GUI broke it?
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/702&gt;
Resolution: | Keywords:
  Platform: All | Cpu: All
Comment (by nikos):
Is this "my" problem as well? Working with latest grass-6.4.0svn, I can't
get any logical "scaling" or "coloring".[[BR]]
( See also @grass-user list: http://n2.nabble.com/nviz---thematic-mapping-
for-vector-points-td3335946.html )
Nikos
Ticket URL: <http://trac.osgeo.org/grass/ticket/702#comment:1&gt;
Comment (by nikos):
Just tried out grass-63 and it works.
Ticket URL: <http://trac.osgeo.org/grass/ticket/702#comment:2&gt;
Comment (by marisn):
Attribute dependent vector rendering in nviz is a huge hack. It was broken
by somebody who was fixing other things, that where broken by attribute
dependent rendering. There are changes in this area in trunk - OGSF now
has a proper mechanism how to set styling, still there's no GUI code for
it. See more: http://lists.osgeo.org/pipermail/grass-dev/2009-
October/046563.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/702#comment:3&gt;
See also #129 a fix for NVIZ site's dependency: elimination of sites lib
dependency
Ticket URL: <https://trac.osgeo.org/grass/ticket/702#comment:4&gt;
Reporter: helena | Owner: grass-dev@…
Priority: major | Milestone: 6.4.1
      Cpu: All |
Changes (by marisn):
  * milestone: 6.4.0 => 6.4.1
Comment:
Will not be fixed for 6.4.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/702#comment:5&gt;
Priority: major | Milestone: 6.4.4
Component: Tcl/Tk NVIZ | Version: 6.4.0 RCs
      Cpu: All |
Changes (by neteler):
  * milestone: 6.4.1 => 6.4.4
Comment:
Is this still an issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/702#comment:6&gt;
      Cpu: All |
Comment(by marisn):
Replying to [comment:6 neteler]:
As I had no time to work on it, and nobody else has stepped to do it, yes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/702#comment:7&gt;
