[GRASS-dev] [GRASS GIS] #706: Location wizard/g.proj: "Do you want to set the default region extents and resolution now?" dialog missing on Windows
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: location wizard | Platform: MSWindows XP
      Cpu: Unspecified |
When creating a new location from georeferenced file (SHAPE with .prj), in
the Location wizard the g.proj part does NOT ask as on Linux "Do you want
to set the default region extents and resolution now?" but returns a
region error message ("region for current mapset is not set", coming from
lib/gis/get_window.c).
Apparently the g.proj call on Windows fails when creating a location from
file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/706&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: location wizard
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Seems ok in latest winGRASS build. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/706#comment:1&gt;
