#708: wxgui georectify: i.rectify runs with -c flag even if "clip to
computational region..." box is not checked
Reporter: mlennert | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: georectify i.rectify -c | Platform: Linux
Cpu: Unspecified |
In the 6.4 svn release branch, in the wxgui georectifier, when you run the
actual georectification, it is always run with -c, regardless of whether
the "clip to computational region in target location" box is checked or
not.
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: 6.4.0 RCs
Resolution: | Keywords: georectify i.rectify -c
Platform: Linux | Cpu: Unspecified
Changes (by cmbarton):
* milestone: 6.4.0 => 6.5.0
Comment:
Fixed for 6.4 in r39385. This probably still needs to be fixed in
develbranch_6 and trunk, but can't backport because they are no longer in
sync with 6.4 in this module. Changing version to 6.5.
