[GRASS-dev] [GRASS GIS] #71: d.vect: disp=cat or attr draws area shapes
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: |
d.vect disp=cat,attr, etc. *without disp=shape* still draws vector areas
(but not lines).
#spearfish:
# area vector: draws labels AND vector areas
d.vect fields disp=cat
d.erase
d.vect fields disp=attr attrcol=label
# line vector: draws only labels
d.erase
d.vect roads disp=cat
d.erase
d.vect roads disp=attr attrcol=label
happens with at least GRASS 6.2.1 - 6.3svn
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/71&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by martinl):
The attached patch
http://trac.osgeo.org/grass/attachment/ticket/71/d-vect-shape-area.diff
should avoid displaying area shape when display=shape is not given. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/71#comment:1&gt;
  Reporter: hamish | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Patch applied in trunk, r30561. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/71#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/71#comment:3&gt;
