[GRASS-dev] [GRASS GIS] #711: r.horizon crashes
Reporter: eblizza | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Keywords: r.horizon | Platform: MSWindows XP
      Cpu: Unspecified |
Hello,
r.horizon terminates after going through a series of matching files past
kernel32.dll that ends with </DATABASE>.
I realize that you are busy, but could you consider fixing this as a
change of pace? I spoke with an ESRI user at MORAP
(www.cerc.usgs.gov/morap/) who needs similar output. If r.horizon worked,
then they might expand to become GRASS users as well.
Alternatively, would you please tell me how to get horizon angles for a
point using ARCMap?
Thank you,
Elizabeth
Ticket URL: <http://trac.osgeo.org/grass/ticket/711&gt;
Resolution: | Keywords: r.horizon
  Platform: MSWindows XP | Cpu: x86-32
Changes (by neteler):
  * cpu: Unspecified => x86-32
Comment:
Please specify in which projection you used r.horizon and with which
parameters.
We need to be able to reproduce the problem...
Ticket URL: <http://trac.osgeo.org/grass/ticket/711#comment:1&gt;
  Priority: normal | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.horizon, wingrass
Changes (by hamish):
  * keywords: r.horizon => r.horizon, wingrass
  * priority: blocker => normal
  * component: default => Raster
Ticket URL: <https://trac.osgeo.org/grass/ticket/711#comment:2&gt;
Comment (by hamish):
n.b. like #736, r.horizon uses pj_*() functions.
maybe a clue there.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/711#comment:3&gt;
Comment (by neteler):
Replying to [comment:3 hamish]:
> maybe a clue there.
Since #736 has been fixed, is r.horizon now working on winGRASS? The
manual page
contains a test example. Can this be closed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/711#comment:4&gt;
Comment (by hellik):
Replying to [comment:4 neteler]:
> > maybe a clue there.
manual page
> Markus
tested with a self compiled actual Grass64 on WinVista32:
r.horizon elevin=dtm@PERMANENT direction=15 horizonstep=30 bufferzone=200
maxdistance=200 horizon=horangle
(Sun Mar 07 21:35:07 2010) Command finished (196 sec) - while r.sunmask is
working in the background
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/711#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.horizon, wingrass
  * status: new => closed
  * resolution: => fixed
Comment:
As it is working now, I am closing. Feel free to reopen if the problem
persists.
Ticket URL: <http://trac.osgeo.org/grass/ticket/711#comment:6&gt;
