[GRASS-dev] [GRASS GIS] #716: The v.krige.py GRASS-Addons crash related to wx.SpinCtrl
Reporter: cgsbob | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: v.krige.py Grass-Addons | Platform: Unspecified
      Cpu: Unspecified |
Running the command
v.krige.py input=elev_lid792_randpts@PERMANENT column=value
output=elev_lid792_randpts_kriging package=gstat
produces this error on a X86_64 Hardy Heron system:
GRASS 6.5.svn (nc_spm_08):~ > v.krige.py
Loading required package: gstat
Loading required package: sp
Loading required package: spgrass6
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.7.0dev, released 2008/11/26
Path to GDAL shared files: /usr/local/share/gdal
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
Loading required package: XML
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: nc_spm_08
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 511, in
<module>
     main()
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 466, in main
     k = KrigingModule(parent=None)
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 375, in
__init__
     self.Panel = KrigingPanel(self)
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 267, in
__init__
     self.CreatePage(package = Rpackage)
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 324, in
CreatePage
     setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 424, in
__init__
     RBookPanel.__init__(self, parent, *args, **kwargs)
   File "/usr/local/grass-6.5.svn/scripts/v.krige.py", line 400, in
__init__
     setattr(self, n+"Ctrl", (wx.SpinCtrl(self, id = wx.ID_ANY,
max=sys.maxint)))
   File "/usr/lib/python2.5/site-packages/wx-2.8-gtk2-
unicode/wx/_controls.py", line 2239, in __init__
     _controls_.SpinCtrl_swiginit(self,_controls_.new_SpinCtrl(*args,
**kwargs))
OverflowError: in method 'new_SpinCtrl', expected argument 8 of type 'int'
It appears to be related to [https://bugs.cihar.com/view.php?id=24]
Ticket URL: <http://trac.osgeo.org/grass/ticket/716&gt;
  Priority: normal | Milestone: 6.5.0
Resolution: | Keywords: v.krige.py Grass-Addons
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * milestone: 6.4.0 => 6.5.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/716#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.krige.py Grass-Addons
Changes (by aghisla):
  * status: new => closed
  * resolution: => fixed
Comment:
fixed in r38607 - goodbye, first ticket of v.krige :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/716#comment:2&gt;
