[GRASS-dev] [GRASS GIS] #719: v.edit tool=break: breaking more then 6 coords and producing of an unexpected line
unexpected line
Reporter: achim | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Keywords: v.edit tool=break | Platform: Unspecified
      Cpu: Unspecified |
1/2
using v.edit tool=break results for more than 6 coordinates in an error:
"Attempt to delete dead feature".
after error message the topology of vector-file is destroyed:
WARNING: Size of 'coor' file differs from value saved in topology file
WARNING: Please rebuild topology for vector map
two equal coordinates result in an error, too
2/2
breaking a line returns three(!) lines: the two desired and one straight
connecting the breaking point and the end or start point of the input-line
Ticket URL: <http://trac.osgeo.org/grass/ticket/719&gt;
unexpected line
Resolution: | Keywords: v.edit tool=break
  Platform: Unspecified | Cpu: Unspecified
Comment (by achim):
2/2
has to do with direction of line. If line direction is flipped, everything
is done alright.
Guess, it has to do with " Vect_append_point" in lines 94, 106, which add
a line to the last! one.?
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:1&gt;
unexpected line
  Reporter: achim | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:2&gt;
unexpected line
Comment (by martinl):
Replying to [ticket:719 achim]:
> 1/2
> 2/2
Can you attach testing data to the ticket (e.g. in GRASS ASCII format -
v.out.ascii format=standard) and exact commands to reproduce buggy
behaviour of v.edit? Thanks. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:3&gt;
unexpected line
Comment (by achim):
Hi, I added a code example. Hope it helps... Achim
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:4&gt;
unexpected line
Comment (by achim):
Forgot:
its EPSG 4326 at
g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 31:27:30N
south: 4:01:30S
west: 23:27E
east: 39:48E
nsres: 0:00:30
ewres: 0:00:30
rows: 4258
cols: 1962
cells: 8354196
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:5&gt;
unexpected line
      Cpu: Unspecified |
Comment(by GG1234):
Hello all,
I am having the same unexpected additional lines when I brake lines of my
map. Is there any hope for this ticket to be resolved in a near future or
should I find a workaround ?
Has anybody ideas of workarounds ? I tried on PostGis with the ST_Split
function but wasn't lucky at using it, and I would rather stay in GRASS if
possible.
Cev.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:6&gt;
unexpected line
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:6 GG1234]:
my map. Is there any hope for this ticket to be resolved in a near future
or should I find a workaround ?
possible.
I will take a look at this issue during Christmas. No promises that it
will help of course:-) Happy Xmas, Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:7&gt;
unexpected line
      Cpu: Unspecified |
Replying to [comment:1 achim]:
> 2/2
everything is done alright.
add a line to the last! one.?
hopefully fixed in r58512 (devbr6).
The command breaks both lines (1 and 2)
v.edit map=network tool=break coords=33.6708333333333,16.9041666666667
You want probably break only line with id 1
id=1
Another option would be to break lines on intersections
v.clean in=network out=network_break tool=break
or
v.edit map=network tool=break id=1-9999
assuming that the map has less them 10e3 lines.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:8&gt;
unexpected line
      Cpu: Unspecified |
Breaking lines with multiple coordinate pairs hopefully fixed in r58516
(GRASS 6.5 only). Note that command
coords=33.6708333333333,16.9041666666667,32.5041666666667,15.6458333333333,33.0208333333333,15.2708333333333
breaks all lines in given bounding boxes. You probably want to break lines
only on intersections (`v.clean tool=break`)
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:9&gt;
unexpected line
      Cpu: Unspecified |
Comment(by GG1234):
Hello Martin,
I am afraid I still have artifacts, see attached picture.
For further debugging, I attach my layer and a txt files with the points
on which I break.
I didn't try the first described bug yet, but will do so ASAP.
Thanks for the help and Merry Christmas to all,
Cev
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:10&gt;
unexpected line
      Cpu: Unspecified |
Replying to [comment:10 GG1234]:
on which I break.
please could you attach also commands to reproduce this bug. I have
imported two shapefiles and created a point map.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:11&gt;
unexpected line
      Cpu: Unspecified |
Comment(by GG1234):
I extracted the commands from the python script I use. Here it is :
def montest():
         print g.run_command('v.patch', quiet=True, overwrite=True, input =
("Support_2","Raccos"), output="network")
         file = open('Conn_Pt2.txt', 'r')
         resultatParse = file.read()
         file.close()
         resultat = resultatParse.split("\n")
         for macoord in resultat[1:]:
                 print "braking at point "+macoord
                 print g.run_command('v.edit', map = "network", layer=1,
tool = 'break', coords = macoord, thresh=1 ,overwrite=True)
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:12&gt;
unexpected line
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.edit tool=break
Changes (by GG1234):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Thanks to Martin's Christmas present the bugs have vanished.
My previous tests were wrong, I guess my Grass build wasn't recent enough.
With a new setup it works like a charm !
Many thanks to Martin for this bug resolution, I will close the ticket.
Any ideas if the fix is also in Grass 7 or will be in near futur ?
Cev.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:13&gt;
unexpected line
  Priority: major | Milestone: 6.4.4
Component: Vector | Version: svn-releasebranch64
Changes (by neteler):
  * version: svn-develbranch6 => svn-releasebranch64
  * milestone: 6.5.0 => 6.4.4
Comment:
Replying to [comment:13 GG1234]:
Reopening since lacking from G6.4 (two differences) and potentially 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:14&gt;
unexpected line
Replying to [comment:14 neteler]:
right, backported to `relbr64` as r58933 and r58934. Could anyone test it
(probably GG1234?)? Thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/719#comment:15&gt;
