#722: r.li.daemon: respect for WORKERS enviro var
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Component: Raster | Version: svn-trunk
Keywords: r.li, smp | Platform: All
Cpu: All |
it would be nice if r.li.daemon respected the WORKERS environment variable
for setting the number of threads to launch.
AFAICS most of the code can be borrowed from trunk/lib/gis/worker.c.
(some doxygen comments would help)
I wonder if both the pthreads and r.li.daemon fork() code should use the
same "GRASS_WORKERS" enviro var instead of the more generic "WORKERS"
name? or is that name some pthreads standard?
or for that matter, if r.li.daemon should be adapted to use the grass7
pthreads support instead of doing its own thing?
