#723: wxGui sqlbuilder: can't launch it
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-trunk
Keywords: sqlbuilder | Platform: Linux
Cpu: x86-64 |
currently I can't get into the wxGUI attribute table SQLBrowser window.
- start wxgui mapset: user1 loc=spearfish
- add vector map (fields@PERM)
- click show attribute table (right most icon on toolbar)
- select Advanced radio button
- click on the `[SQL Builder]` button.
I get this error in the Command Output window:
.../etc/wxpython/gui_modules/dbm.py", line
1893, in OnBuilder
vectorName=self.vectorName)
TypeError
__init__() got an unexpected keyword argument 'vectorName'
If I edit gui/wxpython/gui_modules/dbm.py as so:
Index: gui/wxpython/gui_modules/dbm.py
--- gui/wxpython/gui_modules/dbm.py (revision 38790)
+++ gui/wxpython/gui_modules/dbm.py (working copy)
@@ -1888,9 +1888,9 @@
def OnBuilder(self,event):
"""!SQL Builder button pressed"""
- self.builder = sqlbuilder.SQLFrame(parent=self, id=wx.ID_ANY,
- title=_("SQL Builder"),
- vectorName=self.vectorName)
+ self.builder = sqlbuilder.SQLFrame(self, wx.ID_ANY,
+ _("SQL Builder"),
+ self.vectorName)
def OnTextEnter(self, event):
pass
I can then at least get into the sqlbrowser GUI.
I hesitate to apply that patch as it is just a shot in the dark and I'm
not sure what the correct usage should be.
As Martin mentions in trac #261, the SQL Builder has some serious issues.
It still does, but I've just fixed a bunch of bugs and now it is somewhat
less broken than it was before.
todo:
- clicking on Column, Operator, Value (get values first) doesn't add the
new text at the end of the statement or at the cursor position. It just
seems to go at the fifth char or so. ??
- Clicking `[Apply]` doesn't send the string back to the Attribute Table
Manager GUI. Instead you get an error on `[Close]`
- How to add support for multi-layer tables?? (see `layer` from L584 in
dbm.py ?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/723>
