[GRASS-dev] [GRASS GIS] #726: MASK GRASS_INFO_WARNING
Reporter: pvanbosgeo | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: MASK, r.mask, startup | Platform: Unspecified
      Cpu: x86-64 |
When starting GRASS in a mapset (work_ethiopia) that has a MASK I get the
following message:
GRASS 6.4.0svn (latlon):~ > WARNING: 'cell/MASK' was found in more mapsets
(also found in
          <work_ethiopia>)
WARNING: 'cell/MASK' was found in more mapsets (also found in <LUVC>)
WARNING: Using <MASK@livestock>
It seems though that it still uses the mask in the opened mapset
(work_ethiopia). I am getting sometimes similar messages when carrying out
a r.mapcalc calculation. Again, it seems the correct MASK is used
nonetheless.
When opening GRASS in a mapset (e.g., mapset work_ethiopia, but with MASK
previously removed) without MASK, I get the following message:
Maybe related to this, when I want to create a MASK in a mapset that has
not yet a MASK, I get the following error message (in the r.mask window
this time, previous messages were in the terminal):
r.mask input=mask_eth@climate
ERROR: MASK already found in current mapset. Delete first or overwrite
The only way to still create a MASK in this mapset is by using the
'overwrite' option.
I am running GRASS 6.4 svn r38795 on Ubuntu 0.04
Best wishes
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/726&gt;
Resolution: | Keywords: MASK, r.mask, startup
  Platform: Unspecified | Cpu: x86-64
Comment (by pvanbosgeo):
Update: I tried the same in different mapsets, and the only mapsets that
seem to show the above-described behavior are the ones I have copied from
a backup into the current location (the original location from which the
mapsets were copied matches the current one, it is in fact an earlier
backup of the current location). I guess therefore that something has gone
wrong when copying the mapsets and this is not a general bug. It would be
good though to know if and how one can copy mapsets from a backup into the
current location.
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/726#comment:1&gt;
  Reporter: pvanbosgeo | Owner: grass-dev@…
      Type: defect | Status: closed
Component: Raster | Version: svn-trunk
Resolution: invalid | Keywords: MASK, r.mask, startup
Changes (by hamish):
  * status: new => closed
  * resolution: => invalid
  * component: Default => Raster
Comment:
Replying to [comment:1 pvanbosgeo]:
> I guess therefore that something has gone wrong when copying
> the mapsets and this is not a general bug. It would be good
> into the current location.
usually 'cp -rp' should do it; just make sure the location is identical
and any SEARCH_PATH in the mapset dir is in sync with the new layout.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/726#comment:2&gt;
