#731: Warming message after removing layer confusing
Reporter: pvanbosgeo | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: remove, delete, message | Platform: Linux
Cpu: x86-64 |
I am not sure this is a bug or I am just not following the logic of the
message, but:
suppose I have both in mapset 'climate' and 'climpred' a layer prec_8.
When deleting the layer 'prec_8' from mapset 'climpred' I get the
following message:
quote>
Removing raster <prec_an>
cell/prec_8' was found in more mapsets (also found in <climpred>)
Using <prec_an@climate>
<unquoute
For me this is confusing as it seems to tell that the layer prec_8 is
deleted from the wrong mapset (which is not the case). If the message is
correct, would it mean that after deleting the layer subsequent actions
using layer prec_8 will take that layer from the mapset climate?? If so I
would suggest to rewrite that message to something like:
quote>
Another laye with the name prec_8 exists in mapset <climate>
Removed prec_8@climpred
<quote
Such a message would be more in line with the (rather straightforward and
clear) message one gets when using a layer in r.mapcalc while a layer with
the same name exists in another mapset.
Paulo
Ticket URL: <http://trac.osgeo.org/grass/ticket/731>
