[GRASS-dev] [GRASS GIS] #736: r.proj fails in wingrass
Reporter: cnielsen | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Raster | Version: unspecified
Keywords: | Platform: MSWindows Vista
      Cpu: x86-32 |
Reported in:
http://www.mail-archive.com/grass-user@lists.osgeo.org/msg09983.html
and
http://n2.nabble.com/r-proj-exe-has-stopped-working-
td3500149.html#a3500149
I tried this with latest standalone and osgeo4w versions with the same
result. "r.proj.exe has stopped working". I also tried r.proj.old with the
same result.
By adding a couple debug lines I found out it is crashing on
[http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/raster/r.proj.seg/main.c#L280
line 280]
pj_print_proj_params(&iproj, &oproj);
Not sure what this means but hopefully someone else does. g.proj -w works
fine but it could still be a PROJ.4 issue.
-Colin
Ticket URL: <http://trac.osgeo.org/grass/ticket/736&gt;
Resolution: | Keywords: r.proj, wingrass
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by hamish):
  * keywords: => r.proj, wingrass
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:1&gt;
Comment (by hamish):
As is the case once again with these wingrass bugs, valgrind finds some
memory errors which are apparently benign on UNIX.
setup:
#get&set region
spearfish> g.region -dbg
#create and enter a LL/WGS84 location
ll_wgs84> g.region n=44.50173527 s=44.37032007 \
             w=-103.87110972 e=-103.62942673 res=0:00:01 -ap
ll_wgs84> CMD="r.proj in=elevation.dem loc=spearfish60 mapset=PERMANENT"
ll_wgs84> valgrind --tool=memcheck --leak-check=yes --show-reachable=yes
$CMD
result:
(GRASS 6.5svn on Debian/Etch 32bit i686 linux)
==5114== Memcheck, a memory error detector.
==5114== Copyright (C) 2002-2006, and GNU GPL'd, by Julian Seward et al.
==5114== Using LibVEX rev 1658, a library for dynamic binary translation.
==5114== Copyright (C) 2004-2006, and GNU GPL'd, by OpenWorks LLP.
==5114== Using valgrind-3.2.1-Debian, a dynamic binary instrumentation
framework.
==5114== Copyright (C) 2000-2006, and GNU GPL'd, by Julian Seward et al.
==5114== For more details, rerun with: -v
==5114==
Input Projection Parameters: +proj=utm +zone=13 +a=6378206.4
+rf=294.9786982 +no_defs +nadgrids=$GISBASE/etc/nad/conus
Input Unit Factor: 1
Output Projection Parameters: +proj=longlat +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Input:
Cols: 633 (633)
Rows: 466 (466)
North: 4928000.000000 (4928000.000000)
South: 4914020.000000 (4914020.000000)
West: 590010.000000 (590010.000000)
East: 609000.000000 (609000.000000)
EW-res: 30.000000
NS-res: 30.000000
Output:
Cols: 868 (871)
Rows: 462 (474)
North: 44.501667 (44.501944)
South: 44.373333 (44.370278)
West: -103.870556 (-103.871111)
East: -103.629444 (-103.629167)
EW-res: 0.000278
NS-res: 0.000278
Allocating memory and reading input map...
==5114== Syscall param write(buf) points to uninitialised byte(s)
==5114== at 0x4000792: (within /lib/ld-2.3.6.so)
==5114== by 0x804BF58: main (main.c:391)
==5114== Address 0x6366A0C is 2,532 bytes inside a block of size 163,840
alloc'd
==5114== at 0x401D38B: malloc (vg_replace_malloc.c:149)
==5114== by 0x4037B8D: G__malloc (alloc.c:41)
==5114== by 0x804C7D7: readcell (readcell.c:68)
  100%
Projecting...
  100%
==5114==
==5114== Invalid read of size 4
==5114== at 0x4010DE9: (within /lib/ld-2.3.6.so)
==5114== by 0x4004B78: (within /lib/ld-2.3.6.so)
==5114== by 0x4006792: (within /lib/ld-2.3.6.so)
==5114== by 0x479246F: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x400B44E: (within /lib/ld-2.3.6.so)
==5114== by 0x4791EDE: _dl_open (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x47946FC: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x479475D: __libc_dlopen_mode (in
==5114== by 0x476E7CF: __nss_lookup_function (in
==5114== by 0x476E8BF: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x47704E5: __nss_passwd_lookup (in
==5114== Address 0x6361B3C is 36 bytes inside a block of size 38 alloc'd
==5114== by 0x4006B83: (within /lib/ld-2.3.6.so)
==5114== by 0x471EB6E: getpwuid_r (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114==
==5114== Conditional jump or move depends on uninitialised value(s)
==5114== at 0x4008ED5: (within /lib/ld-2.3.6.so)
==5114== by 0x47928C4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x471E499: getpwuid (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114==
==5114== at 0x4008B2E: (within /lib/ld-2.3.6.so)
==5114==
==5114== at 0x4010DD3: (within /lib/ld-2.3.6.so)
==5114== by 0x6468169: (within
/lib/tls/i686/cmov/libnss_compat-2.3.6.so)
==5114== by 0x646928C: _nss_compat_getpwuid_r (in
==5114== Address 0x6392C18 is 32 bytes inside a block of size 35 alloc'd
==5114== by 0x471EA94: getpwuid_r (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114==
==5114== by 0x400A1F6: (within /lib/ld-2.3.6.so)
==5114== by 0x400A3CA: (within /lib/ld-2.3.6.so)
==5114== by 0x47924D4: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== Address 0x6361FCC is 36 bytes inside a block of size 37 alloc'd
r.proj complete.
==5114==
==5114== ERROR SUMMARY: 521 errors from 6 contexts (suppressed: 107 from
1)
==5114== malloc/free: in use at exit: 897,236 bytes in 217 blocks.
==5114== malloc/free: 1,756 allocs, 1,539 frees, 1,195,737 bytes
allocated.
==5114== For counts of detected errors, rerun with: -v
==5114== searching for pointers to 217 not-freed blocks.
==5114== checked 2,934,108 bytes.
==5114==
==5114==
==5114== 1 bytes in 1 blocks are still reachable in loss record 1 of 19
==5114== at 0x401DB31: operator new(unsigned) (vg_replace_malloc.c:163)
==5114== by 0x565226F: (within /usr/lib/libgeos.so.2.2.3)
==5114== by 0x56A1F04: (within /usr/lib/libgeos.so.2.2.3)
==5114== by 0x5617938: (within /usr/lib/libgeos.so.2.2.3)
==5114== by 0x400B7F4: (within /lib/ld-2.3.6.so)
==5114== by 0x400B920: (within /lib/ld-2.3.6.so)
==5114== by 0x40007EE: (within /lib/ld-2.3.6.so)
==5114==
==5114==
==5114== 1 bytes in 1 blocks are still reachable in loss record 2 of 19
==5114== by 0x56721DF: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 8 bytes in 1 blocks are still reachable in loss record 3 of 19
==5114== by 0x5686C5D: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 16 bytes in 1 blocks are still reachable in loss record 4 of 19
==5114== by 0x5629523: geos::GeometryFactory::GeometryFactory() (in
==5114== by 0x562425A: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 16 bytes in 1 blocks are still reachable in loss record 5 of 19
==5114== by 0x5624250: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 24 bytes in 1 blocks are still reachable in loss record 6 of 19
==5114== by 0x56A0DEF: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 28 bytes in 1 blocks are still reachable in loss record 7 of 19
==5114== by 0x566001F: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 40 bytes in 5 blocks are indirectly lost in loss record 8 of 19
==5114== by 0x476E5CD: __nss_lookup_function (in
==5114== by 0x6468187: ???
==5114== by 0x646928C: ???
==5114== by 0x4072CDC: G_whoami (whoami.c:70)
==5114== by 0x4050B98: G_short_history (history.c:207)
==5114== by 0x403D48C: close_new (closecell.c:311)
==5114== by 0x403CBD7: G_close_cell (closecell.c:81)
==5114== by 0x804C2BF: main (main.c:448)
==5114==
==5114==
==5114== 80 bytes in 5 blocks are indirectly lost in loss record 9 of 19
==5114== by 0x475B84B: tsearch (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x476E58E: __nss_lookup_function (in
==5114== by 0x6468169: ???
==5114==
==5114==
==5114== 140 bytes in 2 blocks are still reachable in loss record 10 of 19
==5114== by 0x46FD17F: strdup (in /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x40E322C: pj_gridinfo_init (in /usr/lib/libproj.so.0.5.4)
==5114== by 0x40E431A: (within /usr/lib/libproj.so.0.5.4)
==5114== by 0x40E44D4: pj_gridlist_from_nadgrids (in
==5114== by 0x40E07B4: pj_apply_gridshift (in
==5114== by 0x40E1B35: pj_datum_transform (in
==5114== by 0x40E1E1C: pj_transform (in /usr/lib/libproj.so.0.5.4)
==5114== by 0x4024146: pj_do_proj (do_proj.c:84)
==5114== by 0x804A055: bordwalk (bordwalk.c:56)
==5114== by 0x804BB8C: main (main.c:309)
==5114==
==5114==
==5114== 156 (36 direct, 120 indirect) bytes in 1 blocks are definitely
lost in loss record 11 of 19
==5114== by 0x476EA09: (within /lib/tls/i686/cmov/libc-2.3.6.so)
==5114== by 0x476F0F6: __nss_database_lookup (in
==5114== by 0x6468149: ???
==5114==
==5114==
==5114== 256 bytes in 1 blocks are still reachable in loss record 12 of 19
==5114== by 0x56721F3: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 256 bytes in 1 blocks are still reachable in loss record 13 of 19
==5114== by 0x5686C3F: (within /usr/lib/libgeos.so.2.2.3)
==5114==
==5114==
==5114== 853 bytes in 80 blocks are definitely lost in loss record 14 of
19
==5114== by 0x405418E: G__location_path (location.c:80)
==5114== by 0x405409E: G_location_path (location.c:41)
==5114== by 0x404F7E4: G__gisinit (gisinit.c:58)
==5114== by 0x804B443: main (main.c:134)
==5114==
==5114==
==5114== 6,696 bytes in 5 blocks are still reachable in loss record 15 of
19
==5114== at 0x401C6CA: calloc (vg_replace_malloc.c:279)
==5114== by 0x4037C00: G__calloc (alloc.c:74)
==5114== by 0x405A4EC: G_parser (parser.c:762)
==5114== by 0x804B638: main (main.c:202)
==5114==
==5114==
==5114== 11,776 bytes in 1 blocks are still reachable in loss record 16 of
19
==5114== by 0x4037C6C: G__realloc (alloc.c:109)
==5114== by 0x4057680: new_fileinfo (opencell.c:42)
==5114== by 0x4057B2A: G__open_cell_old (opencell.c:274)
==5114== by 0x4057740: G_open_cell_old (opencell.c:104)
==5114== by 0x804BF26: main (main.c:389)
==5114==
==5114==
==5114== 20,191 bytes in 7 blocks are still reachable in loss record 17 of
19
==5114== at 0x401D487: realloc (vg_replace_malloc.c:306)
==5114== by 0x4037C83: G__realloc (alloc.c:111)
==5114== by 0x4046128: set_env (env.c:156)
==5114== by 0x404683A: G__setenv (env.c:391)
==5114== by 0x405953D: G_check_overwrite (overwrite.c:65)
==5114== by 0x804B621: main (main.c:200)
==5114==
==5114==
==5114== 265,380 bytes in 19 blocks are still reachable in loss record 18
of 19
==5114== by 0x40DE25D: pj_malloc (in /usr/lib/libproj.so.0.5.4)
==5114== by 0x40DEECF: pj_mkparam (in /usr/lib/libproj.so.0.5.4)
==5114== by 0x40DD441: pj_init (in /usr/lib/libproj.so.0.5.4)
==5114== by 0x402373F: pj_get_kv (get_proj.c:228)
==5114== by 0x804B82D: main (main.c:234)
==5114==
==5114==
==5114== 591,438 bytes in 83 blocks are still reachable in loss record 19
of 19
==5114== by 0x406E110: G_store (store.c:36)
==5114== by 0x4062D0C: G_set_program_name (progrm_nme.c:52)
==5114== by 0x404F79C: G__gisinit (gisinit.c:51)
==5114==
==5114== LEAK SUMMARY:
==5114== definitely lost: 889 bytes in 81 blocks.
==5114== indirectly lost: 120 bytes in 10 blocks.
==5114== possibly lost: 0 bytes in 0 blocks.
==5114== still reachable: 896,227 bytes in 126 blocks.
==5114== suppressed: 0 bytes in 0 blocks.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:2&gt;
Comment (by jef):
Replying to [ticket:736 cnielsen]:
line 280]
[http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/proj/get_proj.c#L396
pj_print_proj_params()] uses G_free() to free a string returned from PROJ,
where it should use pj_free().
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 jef]:
Fixed in r38873 (7.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:4&gt;
Comment (by martinl):
Replying to [comment:4 glynn]:
Backported in r38874 (6.5) and r38875 (6.4).
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:5&gt;
Comment (by cnielsen):
Not fixed yet. Same error comes up after update. It prints the "Input
Projection Parameters" which is the line above the now pj_free, but hangs
at pj_free
[http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/proj/get_proj.c?rev=38875#L405
line 405 of get_proj.c]
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:6&gt;
Comment (by jef):
Replying to [comment:6 cnielsen]:
at pj_free
Ouch. It's not pj_free(), it's pj_dalloc() (just like in #537).
Sorry.
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:7&gt;
Comment (by jef):
Replying to [comment:7 jef]:
> Sorry.
And #468. How embarassing - sorry again.
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:8&gt;
jef:
so, does the patch test out ok & shall we commit it?
Index: lib/proj/get_proj.c
--- lib/proj/get_proj.c (revision 38897)
+++ lib/proj/get_proj.c (working copy)
@@ -402,7 +402,7 @@
         if (str != NULL) {
             fprintf(stderr, "%s: %s\n", _("Input Projection Parameters"),
                     str);
- pj_free(str);
+ pj_dalloc(str);
             fprintf(stderr, "%s: %.16g\n", _("Input Unit Factor"),
                     iproj->meters);
@@ -415,7 +415,7 @@
         if (str != NULL) {
             fprintf(stderr, "%s: %s\n", _("Output Projection Parameters"),
                     str);
- pj_free(str);
+ pj_dalloc(str);
             fprintf(stderr, "%s: %.16g\n", _("Output Unit Factor"),
                     oproj->meters);
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:9&gt;
Comment (by glynn):
Replying to [comment:9 hamish]:
Ouch. I can't be the only person to have been tripped up by that one.
Any chance of getting the PROJ developers to rename pj_free() to e.g.
pj_free_proj()?
Yes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:10&gt;
Works on winGrass. Commit it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/736#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.proj, wingrass
  * status: new => closed
  * resolution: => fixed
Comment:
Ok guys, patch submitted on all branches. Thanks!
Glynn:
> that one.
> to e.g. pj_free_proj()?
I think you'll have to take that up with them directly.
Hamish
ps- I still would like to learn a bit more about how to deal with there
errors which Valgrind finds; leaving them there but ignoring them seems
like an unscratched itch. Currently I can make the reports but it's
frustrating having done that not knowing what to do next.
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:12&gt;
Comment (by jef):
Replying to [comment:12 hamish]:
Without reviewing the valgrind log in detail, I'd just expect memory
leaks. Those just waste memory and are otherwise harmless, unless you run
out of memory because of them.
It didn't point to the crash. Actually it can't as there isn't any
problem valgrind could detect, because on Unix there isn't any. On Unix
the runtime library (aka libc) provides {{{malloc()}}} and {{{free()}}}
and deals with memory management for the whole process - including shared
libraries.
On Windows OTOH each DLL can have it's own runtime library and each call
to {{{malloc()}}} must be matched with a call to {{{free()}}} from the
same library.
Therefore each DLL provides a function to free allocated memory they
return, that simply calls {{{free()}}}, but from the runtime library they
use - eg. {{{pj_dalloc()}}} for PROJ, {{{CPLFree()}}} for GDAL/OGR and
{{{G_free()}}} for GRASS).
Still you won't run into problems if you compile everything using the same
runtime library, eg. one version of MinGW.
On Unix one could also call any of those or {{{free()}}} directly, without
causing problems. But one still shouldn't as the functions might do more
than just {{{free()}}} in the future. That's also why I'd consider those
issues bugs even on Unix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/736#comment:13&gt;
