[GRASS-dev] [GRASS GIS] #739: v.mkgrid parameter needs two values but is multiple=NO
Reporter: rsbivand | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
When run from the command line, v.mkgrid map=xxx grid=100,50 works
(main.c, line 74), but in wxpython and execGRASS() in spgrass6 in R, the
--interface-description of grid->multiple = NO is respected, and only one
value can be passed. This then fails (in wxpython here) with:
v.mkgrid --overwrite map=grd grid=100
ERROR: option <grid> must be provided in multiples of 2
        You provided 1 items:
        100
In R (using --interface-description):
> execGRASS("v.mkgrid", flags="overwrite", parameters=list(map="grd",
grid=as.integer(100)))
        100
or:
grid=rep(as.integer(100), 2)))
Error in doGRASS(cmd, flags = flags, parameters = parameters) :
   Parameter <grid> has multiple values
This conflicts with the single comma in grid->key_desc, which implies two
values, but grid->multiple = NO. The same seems to apply to box=. It looks
as though there is no conflict on the command line when multiple = NO
provided that the number of values agrees with # commas in key_desc plus
one, but that this does not work when --interface description is used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/739&gt;
Component: Vector | Version: 6.4.0 RCs
Resolution: | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by rsbivand):
  * version: unspecified => 6.4.0 RCs
  * component: default => Vector
Ticket URL: <http://trac.osgeo.org/grass/ticket/739#comment:1&gt;
Comment (by neteler):
Replying to [ticket:739 rsbivand]:
> 100
Yes, it must be 100,100 (the user has to specify two values).
> 100
here you need to use
... grid=paste(as.integer(100), as.integer(100), sep=",")
> or:
Yes, because
[1] 100 100
which is space but not comma separated. Indeed you need to use:
[1] "100,100"
two values, but grid->multiple = NO. The same seems to apply to box=. It
looks as though there is no conflict on the command line when multiple =
NO provided that the number of values agrees with # commas in key_desc
plus one, but that this does not work when --interface description is
used.
I don't think that this is a conflict: two comma separated values are
taken as one "string".
Instead, e.g. in r.series, multiple input maps are possible which are
multiple = YES, hence,
they are treated as separate tokens.
Ticket URL: <http://trac.osgeo.org/grass/ticket/739#comment:2&gt;
> 100
> 100
No,
    grid=paste(as.integer(100), as.integer(100), sep=",")))
   Parameter <grid> does not have integer value
because doGRASS() checks the type, and with c(as.integer(100),
   as.integer(100)) would concatenate correctly with a comma.
The problem is in the wrong setting of grid->multiple as NO, which simply isn't examined from the command line. The wxpython GUI version has exactly the same problem.
Thanks for checking!
Roger
> or:
Yes, because
[1] 100 100
[1] "100,100"
used.
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
No,
I see (if possible, could we have the debug output of R?).
the same problem.
For me it works in GRASS 6.5 wxGUI, also in the (current) 6.4.svn.
No,
the same problem.
The problem is that the GRASS parser adopts an illogical view of multiple=NO, and overrides it when there is a comma in keydesc. This means that I am obliged to make parseGRASS() even more byzantine than before, to admit multiple integers and floats where multiple=NO and the length of the R object of the correct storage mode is > 1 (strings can be obfuscated in the way you suggest). I'll try to mimic the IMHO very bad behaviour of the parser.
Couldn't multiple take values YES, NO, or the integer count required if the count is known, as here? multiple=2 would be easy to parse.
Repeating, the 6.4 wxpython menu entry Vector -> Generate grid is broken for me 6.4.0svn, but not current, because the widget for entering grid only accepts a single integer (as per --interface-description).
In current 6.4.0svn the widget has been changed to a text widget, so that's why it works, but does not check for integer:
v.mkgrid --overwrite map=grd@rsb grid=99.3de,101.5abc
also runs, probably by rounding to integer.
I'll try to work around the parsing muddle, but will check that the values given are both integer.
Roger
Roger Bivand
Resolution: | Keywords: v.mkgrid
Changes (by hamish):
  * keywords: => v.mkgrid
Comment:
Roger wrote: (please reply in-ticket)
easy to parse.
Roger
It's not illogical; it's just unintuitive in the wxGUI as some critical
information is not being displayed.
It should take it's cue from both opt->key_desc and opt->multiple.
e.g. r.what with multiple=YES has east_north=x1,y1[,x2,y2[,...]]
if you give 3 values it complains that it wants a multiple of two.
or d.legend opt7->key_desc = "bottom,top,left,right"; but there
multiple sets of four = NO;
this works quite well in the C parser.
you are right, in the wxGUI for v.mkgrid it gives you no indication
that you should do "rows,columns" for the required grid option. It just
says (grid, integer)
In the tcltk GUI you get a bit more info:
  (grid, rows,columns, required)
coor= is perhaps a more obvious example.
  (coor, x,y, optional)
the help page, --help USAGE is the best:
  grid=rows,columns [coor=x,y]
grid=rows,columns
     Number of rows and columns in grid
that the parser doesn't check by type as well as it could is another issue
for another ticket.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/739#comment:3&gt;
Comment (by hamish):
in latest 6.4svn I can successfully run v.mkgrid from the wxGUI with:
   v.mkgrid map=testgrid grid=5,5
... as long as I know to put 5,5 in the "grid" entry.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/739#comment:4&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: v.mkgrid
  * status: new => closed
  * resolution: => wontfix
Comment:
OK, I'll back off, too much legacy stuff depends on multiple keydescs
being coded with multiple as NO. I've added keydesc detection and parsing
to parseGRASS() in spgrass6, since the alternative would break things in
GRASS itself.
Ticket URL: <http://trac.osgeo.org/grass/ticket/739#comment:5&gt;
