[GRASS-dev] [GRASS GIS] #74: v.digit option to set background colour doesn't work
Reporter: craigleat | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.3.0
Component: default | Version: svn-trunk
Keywords: v.digit |
It appears that the v.digit option: settings -> Symbology -> Background is
broken, because I am unable to change the background colour. A further
annoyance is that the background colour changes from white to cyan
whenever a background vector is added. If a raster is added the background
stays white.
Tested with Spearfish.
Ticket URL: <http://trac.osgeo.org/grass/ticket/74&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
#74: Tcl version of v.digit's background colour doesn't work
Resolution: | Keywords: v.digit, Tcl
Changes (by hamish):
  * keywords: v.digit => v.digit, Tcl
  * summary: v.digit option to set background colour doesn't work => Tcl
              work
Comment:
Confirmed.
It's not just vector backdrop maps which turn the background color cyan,
"d.grid 5000" does it too.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:1&gt;
Comment (by hamish):
raster maps do turn the background cyan if you use the -o overlay flag
with d.rast.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:2&gt;
with d.rast.
I think I've fixed this with r30805.
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.digit, Tcl
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed by Glynn with r30805. Also backported to 6.3.0-relbranch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:3&gt;
      Type: defect | Status: reopened
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Glynn:
The background color is now white, but changing the background color from
the Setting window Symbology tab (1st item) still doesn't work as
expected.
With r30810 (just committed) it now respects the bg color, but only if you
add a background command like 'd.grid 5000'. I also notice that you can't
turn off background commands once created, unchecking their tick boxes has
no visible effect, once rendered. (if not yet rendered it won't draw it if
unticked)
To make the bg cmd go away you need to fully delete the command text.
(putting a # at the start of the line could work too? but not well)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:4&gt;
Right. A simple (but inefficient) solution would be to add a d.erase
command at the beginning of the list.
It should be possible to set the canvas background colour with:
  .screen.canvas configure -bg <color>
unticked)
The background should be re-calculated whenever a full redraw occurs,
e.g. if you change the zoom or click the redraw button.
  Priority: minor | Milestone: 6.4.0
  * milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:5&gt;
Resolution: worksforme | Keywords: v.digit, Tcl
  Platform: Unspecified | Cpu: Unspecified
Changes (by cmbarton):
  * status: reopened => closed
  * platform: => Unspecified
  * resolution: => worksforme
  * cpu: => Unspecified
* cc: hamish_nospam@yahoo.com (added)
Comment:
I've just tested in 15-08-08 SVN develbranch_6. All of these problems seem
to be fixed, at least in the Mac version. I have some odd mouse behavior (
middle-click acting like right-click), but that could be a function of
using TclTk 8.5 aqua. Could you please check and see if we can close this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:6&gt;
Changes (by craigleat):
* cc: hamish_nospam@yahoo.com (removed)
  * resolution: worksforme =>
Comment:
Hamish:
>it now respects the bg color, but only if you add a background command
like 'd.grid 5000'
Agreed. The bg colour reverts to white if the bg command is
disabled/removed.
Hamish:
>I also notice that you can't turn off background commands once created
No, the toggle button works for me. Prefixing the command with a # also
works.
Michael:
>I have some odd mouse behavior (middle-click acting like right-click)
My mouse clicks work as expected.
Tested with GRASS 6.4 revision 32853 of 18 Aug 2008, Ubuntu 7.10 and Tcl
8.4.
Craig
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:7&gt;
Replying to [comment:7 craigleat]:
> Hamish:
craigleat:
works.
s/turn off/remove/
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:8&gt;
* cc: glynn@gclements.plus.com (added)
Comment:
I don't understand the 's/turn off/remove/'
I just checked again. I have no problem with the background color settings
on my Mac with the current GRASS 6.4 compiled from the SVN develbranch_6.
The vector itself is in the first "background", but that shouldn't be
turned off of course. Glynn revamped the code so as to use a TclTk canvas
instead of an xwin. Maybe he can look at this too. It seems OK to me
though.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:9&gt;
Comment (by craigleat):
Michael:
>I have no problem with the background color settings on my Mac
A TclTk bug perhaps? I have the problem with TclTk 8.4, but it works for
Michael who is using TclTk 8.5.
Craig
PS This is a minor bug, maybe we just live with it and add a note to the
manual page.
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:10&gt;
Comment (by glynn):
In r32876, the canvas' background colour is updated whenever the
background setting changes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:11&gt;
* cc: hamish_b@yahoo.com (added)
Comment:
Well done Glynn and thanks. It works correctly now (for me at least). I'll
allow Hamish to test further and resolve as 'fixed'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/74#comment:12&gt;
