#744: package.sh for compiling on windows
Reporter: hellik | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: svn-develbranch6
Keywords: Compiling, MS Win | Platform: MSWindows Vista
Cpu: Unspecified |
taken from http://lists.osgeo.org/pipermail/grass-user/2009-
September/052261.html:
hi
i've looked at package.sh at rev39042 for develbranch65:
Resolution: | Keywords: wingrass
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by cnielsen):
I've updated the CompileOnWindows wiki page to reflect recent updates to
package.sh. Look at the GRASS-6.4.0 section and adapt the line numbers for
develbranch_6.
The default paths were from Jurgen, but as hamish noted in a comment in
r39046, these should probably be changed to be more general.
%PROGRAMFILES% wouldn't be so good because of continuing issues with
paths-with-spaces, but maybe it should be changed to /c/osgeo4w/ to
reflect the suggested path in CompileOnWindows?
I added instructions to remove the {{{-j4}}} from the make command because
I got errors, similarly with the bottom half of the script which is
designed to build osgeo4w packages (using VC) and isn't needed for normal
builds... but maybe I'm missing something.
Comment (by hellik):
thanks for updating the wiki!
And comment out (by adding a # to the start of the line) to lines 83-85,
e.g.: #cp /c/mingw/bin/libgnurx-0.dll $OSGEO_ROOT_MSYS/bin #cp /c/mingw/bin/libiconv-2.dll $OSGEO_ROOT_MSYS/bin #cp /c/mingw/bin/libintl-8.dll $OSGEO_ROOT_MSYS/bin
Replying to [comment:3 hellik]:
e.g.:
> shouldn't this lines 87-89?
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/mswindows/osgeo4w/package.sh#L87
