[GRASS-dev] [GRASS GIS] #746: v.out.ascii with column parameter: segfault
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: | Platform: Linux
      Cpu: x86-64 |
I get a Heisenbug when exporting points from v.out.ascii with attributes
(Scientific Linux 5, 64bit):
GRASS 6.4.0svn (patUTM32):~ > v.out.ascii phd_area_main_cities column=name
Segmentation fault
GRASS 6.4.0svn (patUTM32):~ > gdb v.out.ascii
GNU gdb Red Hat Linux (6.5-37.el5_2.2rh)
This GDB was configured as "x86_64-redhat-linux-gnu"...(no debugging
symbols found)
Using host libthread_db library "/lib64/libthread_db.so.1".
(gdb) r phd_area_main_cities column=name
Starting program:
/home/neteler/binaries/grass-6.4.0svn/bin/v.out.ascii
(no debugging symbols found)
[Thread debugging using libthread_db enabled]
[New Thread 47548720613104 (LWP 7517)]
[Detaching after fork from child process 7520. (Try `set detach-on-fork
off'.)]
664070.15136424|5103723.69345589|1|Trento
680631.89931785|5152080.37972013|2|Bolzano - Bozen
748566.88848245|5114436.80436153|3|Belluno
753217.48877466|5062320.47156408|4|Treviso
783478.0559796|5095956.26859946|5|Pordenone
Program exited normally.
Segmentation fault
Yes, I didn't compile with -g because it is my production machine but
since it works in GDB...
Sample location with small dataset attached.
Ticket URL: <http://trac.osgeo.org/grass/ticket/746&gt;
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-64
Comment (by hamish):
Hamish:
> > see also v.in.ascii column wish/bug + patch in trac bug list
> > https://trac.osgeo.org/grass/report/13
Markus:
> Is https://trac.osgeo.org/grass/ticket/198
> related? I see a patch sleeping there...
no sorry, I saw v.in.ascii not v.out.ascii. Nevermind.
ah, I can reproduce this on 64bit + CFLAGS=-g but not on 32bit + -g
with gras 6.5svn.
hmph. 50% of the time it completes successfully. Sometimes I need to exit
and restart GRASS to stir up the memory pool enough to get it to segfault
again.
D1/1: Info->size = 159, Info->mtime = 1252533415
D1/1: coor size in head = 159, real coor file size= 159
D1/1: Vect_open_old(): vector opened on level 1
D1/1: Vect_read_dblinks(): map = phd_area_main_cities, mapset = markus
D1/1: dbln file:
/home/hamish/grassdata/utm32/markus/vector/phd_area_main_cities/dbln
D1/1: dbln: 1 phd_area_main_cities cat
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/1: field = 1 name = (null), table = phd_area_main_cities, key = cat,
database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
D1/1: Dblinks read
D1/1: Vect_Rewind(): name = phd_area_main_cities
D1/1: Vect_get_field(): field = 1
D1/1: Vect_get_dblink(): link = 0
Segmentation fault
ok, got it to fail with DEBUG=5:
D4/5: row 3
D4/5: eval_node node_type = 3
D4/5: eval_node node_type = 1
D4/5: left = 2
D4/5: left_dval = 4.000000
D4/5: eval_node node_type = 2
D4/5: right = 2
D4/5: right_dval = 1.000000
D4/5: operator = 11
D4/5: condition = 0
D4/5: row 4
D4/5: left = 2
D4/5: left_dval = 5.000000
D4/5: right = 2
D4/5: operator = 11
D4/5: condition = 0
D2/5: load_table_head(): tab = 0,
/home/hamish/grassdata/utm32/markus/dbf//phd_area_main_cities.dbf
Segmentation fault
it seems to die on this in db_select_value():
if (count == 0)
     db_copy_value(val, value);
I'm guessing that *val has not been allocated any memory?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:1&gt;
Replying to [comment:1 hamish]:
> if (count == 0)
in v.out.ascii/b2a.c bin_to_asc() there is
      dbValue value;
but dbValue is a struct (see include/dbmi.h) which contains a
dbString which contains char *string, which needs an alloc...
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:2&gt;
I get a bit more out of valgrind,
==28766== Conditional jump or move depends on uninitialised value(s)
==28766== at 0x4C22D89: strlen (mc_replace_strmem.c:242)
==28766== by 0x7356CB0: vfprintf (in /lib/libc-2.7.so)
==28766== by 0x7357B5F: (within /lib/libc-2.7.so)
==28766== by 0x7353435: vfprintf (in /lib/libc-2.7.so)
==28766== by 0x52A8270: G_debug (debug.c:83)
==28766== by 0x591A98F: db_select_value (select.c:230)
==28766== by 0x402473: bin_to_asc (b2a.c:217)
==28766== by 0x40310A: main (out.c:185)
==28766==
==28766== at 0x4C22D98: strlen (mc_replace_strmem.c:242)
==28766==
==28766== Syscall param write(buf) points to uninitialised byte(s)
==28766== at 0x73D09F0: write (in /lib/libc-2.7.so)
==28766== by 0x737E909: _IO_file_write (in /lib/libc-2.7.so)
==28766== by 0x737E569: (within /lib/libc-2.7.so)
==28766== by 0x737E84D: _IO_file_xsputn (in /lib/libc-2.7.so)
==28766== by 0x7357C09: (within /lib/libc-2.7.so)
==28766== Address 0x7feffcc6a is on thread 1's stack
==28766==
==28766== at 0x507E6BF: db_enlarge_string (string.c:113)
==28766== by 0x507E657: set_string (string.c:92)
==28766== by 0x507E588: db_set_string (string.c:35)
==28766== by 0x507E8AA: db_copy_string (string.c:214)
==28766== by 0x507F546: db_copy_value (value.c:319)
==28766== by 0x591A9BB: db_select_value (select.c:235)
==28766==
==28766== Use of uninitialised value of size 8
==28766== at 0x4C22DFC: strcpy (mc_replace_strmem.c:268)
==28766== by 0x507E678: set_string (string.c:95)
==28766==
==28766== Invalid write of size 1
==28766== Address 0x7ffffffff is not stack'd, malloc'd or (recently)
free'd
==28766==
==28766== Process terminating with default action of signal 11 (SIGSEGV)
==28766== Access not within mapped region at address 0x7FFFFFFFF
==28766==
==28766== ERROR SUMMARY: 8 errors from 6 contexts (suppressed: 20 from 2)
==28766== malloc/free: in use at exit: 23,975 bytes in 131 blocks.
==28766== malloc/free: 292 allocs, 161 frees, 47,116 bytes allocated.
==28766== For counts of detected errors, rerun with: -v
==28766== searching for pointers to 131 not-freed blocks.
==28766== checked 2,826,664 bytes.
==28766==
==28766== LEAK SUMMARY:
==28766== definitely lost: 369 bytes in 16 blocks.
==28766== possibly lost: 58 bytes in 1 blocks.
==28766== still reachable: 23,548 bytes in 114 blocks.
==28766== suppressed: 0 bytes in 0 blocks.
==28766== Rerun with --leak-check=full to see details of leaked memory.
Segmentation fault
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:3&gt;
Comment (by glynn):
if (count == 0)
Various dbString functions expect the target value to have been
initialised, but "value" is uninitialised. It needs to be initialised
with:
     dbValue value = {0};
Alternatively, the string part alone can be initialised later with:
     db_init_string(&value.s);
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:4&gt;
Comment (by neteler):
Replying to [comment:4 glynn]:
with:
Is attached patch ok?
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 neteler]:
with:
I suggest using an initialiser; try r39121.
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Thanks, seems to help. Backported. Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/746#comment:7&gt;
