[GRASS-dev] [GRASS GIS] #752: wxGUI: wrong map layer adjustment for opacity
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: x86-64 |
in the wxGUI layer manager windows, if you click on the little Preferences
button (hey could that be packed on the far right? it would be much
cleaner) ... while another layer line is highlighted you get a context
menu. If you select change opacity and change it, the highlighted layer
row is modified, not the one you right clicked on. If you click on the
layer map name and not the preferences button it works as expected.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/752&gt;
Resolution: | Keywords: layer manager, properties
  Platform: Linux | Cpu: x86-64
Changes (by martinl):
  * keywords: => layer manager, properties
Comment:
Yes, this is know bug (seems to be not report in trac till this time).
Ticket URL: <https://trac.osgeo.org/grass/ticket/752#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: layer manager, properties
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in releasebranch_64 (r39992), in develbranch_6 (r39991) and
backported to trunk (r39992). Options button is disabled unless layer is
selected.
Ticket URL: <http://trac.osgeo.org/grass/ticket/752#comment:2&gt;
