[GRASS-dev] [GRASS GIS] #757: WinGRASS: GUI window from cmd line
Reporter: silviap | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
When starting GRASS with the MinGW shell it just gives the help in the
shell, rather than opening the module's dialog.
Ticket URL: <http://trac.osgeo.org/grass/ticket/757&gt;
Resolution: | Keywords:
  Platform: MSWindows 2K | Cpu: Unspecified
Changes (by martinl):
  * platform: Unspecified => MSWindows 2K
Comment:
Please specify at least the platform and GRASS version...
Ticket URL: <http://trac.osgeo.org/grass/ticket/757#comment:1&gt;
      Type: task | Status: new
  Priority: trivial | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
  Platform: MSWindows XP | Cpu: Unspecified
Changes (by silviap):
  * priority: normal => trivial
  * platform: MSWindows 2K => MSWindows XP
  * version: unspecified => 6.4.0 RCs
  * component: default => wxGUI
  * type: defect => task
Ticket URL: <http://trac.osgeo.org/grass/ticket/757#comment:2&gt;
Comment (by hamish):
which icon did you start with? The blue "M" or the blue "M" with the GRASS
logo in it or another?
which version of 6.4.0rc5 or svn r12345? Installed from the Osgeo4w
installer or Colin's native binary?
If you type "g.gui" at the grass prompt and press return, what happens?
perhaps send a screenshot?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:3&gt;
Comment (by silviap):
Replying to [comment:3 hamish]:
GRASS logo in it or another?
The blue M (MinGW shell)
native Stand-alone Installer package by Colin Nielsen
Sorry, I don't have any windows right now..
silvia
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:4&gt;
> > with the GRASS logo in it or another?
Replying to [comment:4 silviap]:
I don't have it running in front of me so I may be mistaken, but I think
the one you want is the M with the grass white diamond logo half over the
top of it, or the white diamond one by itself. I think the blue M alone is
just the MSys UNIX shell ... not actually GRASS at all. :slight_smile:
try this one:
source:grass/trunk/mswindows/Installer-Files/GRASS_MSys.ico
or try this one:
source:grass/trunk/mswindows/Installer-Files/GRASS.ico
but not this:
source:grass/trunk/mswindows/Installer-Files/MSYS_Custom_Icon.ico
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:5&gt;
Replying to [comment:5 hamish]:
I don't have it running in front of me as well... so it was the M with the
grass logo, not just the MSys icon - the grass shell and not just the MSys
Unix shell. Colin agrees that it just gives the help in the shell, rather
than opening the module's dialog. So I just opened a ticket.
> try this one:
> or try this one:
> but not this:
> Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:6&gt;
Comment (by cnielsen):
A bit of misunderstanding here. GRASS is starting fine, but once open the
dialogs of individual modules aren't opening when they are typed into the
shell. Instead if you type {{{ r.walk }}} or whatever, the module's ascii
help text is output to the shell (as required arguments are missing, ie.
output) instead of opening a dialog window where the arguments may be
entered.
-Colin
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:7&gt;
Replying to [comment:7 cnielsen]:
the dialogs of individual modules aren't opening when they are typed into
the shell. Instead if you type {{{ r.walk }}} or whatever, the module's
ascii help text is output to the shell (as required arguments are missing,
ie. output) instead of opening a dialog window where the arguments may be
entered.
> -Colin
GRASS is starting fine, thank you for explaining it better and sorry for
creating the misunderstanding.
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:8&gt;
Comment (by glynn):
entered.
When you run the command without arguments, the GUI interface is only
generated if stdin is a terminal, according to isatty().
On Windows, isatty() only recognises the standard Windows Command Prompt
as a terminal. The MSys terminal (rxvt) isn't considered a terminal by
isatty() (AFAICT, any child processes will have their standard descriptors
connected to pipes).
I'm not sure that there is anything which can be done about this, other
than skipping the isatty() check altogether on Windows (although that may
be an acceptable solution; I don't know of a reason why the check is
actually necessary).
You can still force a GUI using the --ui switch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:9&gt;
Reporter: silviap | Owner: grass-dev@…
Keywords: wingrass | Platform: MSWindows XP
      Cpu: Unspecified |
Changes (by hellik):
  * keywords: => wingrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/757#comment:10&gt;
      Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:8 silviap]:
entered.
> > -Colin
closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/757#comment:11&gt;
      Type: task | Status: closed
Resolution: wontfix | Keywords: wingrass
Changes (by hamish):
  * status: new => closed
  * resolution: => wontfix
Comment:
> interface is only generated if stdin is a terminal,
> Windows Command Prompt as a terminal. The MSys
> terminal (rxvt) isn't considered a terminal by isatty()
the problem is well understood; I just tested and the --ui work-around
still works; closing the ticket with the nearest reason to "cantfix".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/757#comment:12&gt;
