#76: Calculation of bearing between 2 points, using d.measure
Reporter: dylan | Owner: grass-dev@lists.osgeo.org
Priority: minor | Milestone: 6.5.0
Component: default | Version: unspecified
Resolution: | Keywords: d.measure
Platform: Unspecified | Cpu: Unspecified
Comment (by dylan):
I understand that the GUI has this functionality, but there are many of us
who do not use the GUI. I have updated the patch to conform to the current
(r39462) version of GRASS65. If it seems like a useless patch, then I will
maintain my own local version.
Comment (by glynn):
Replying to [comment:1 dylan]:
> Has anyone had a chance to review this patch for submission to trunk
yet?
The "trunk" is 7.0, which doesn't have d.measure or the functionality it
requires (the ability to query the mouse pointer).
The code is still there, but it doesn't compile due to the absence of
R_get_location_with_pointer(). It was retained in case it was felt
worthwhile to modify it to take x,y coordinates via command-line options
or stdin, rather than via the mouse. As the functionality has been added
directly to the GUI, it's likely that d.measure will be removed
altogether.
Comment (by martinl):
Replying to [comment:5 glynn]:
yet?
altogether.
What about m.measure in GRASS 7? This module could read x,y coordinates
from stdin as you suggested. The module could used by GUI.
Comment (by glynn):
Replying to [comment:6 martinl]:
That possibility was why d.measure was retained.
Whether such a module should be called m.measure (or g.measure) or
d.measure depends upon whether the coordinates are cartographic
coordinates or display coordinates.
- Reporter: dylan | Owner: grass-dev@lists.osgeo.org Type:
- Comment (by glynn):
yet?
altogether.
Ah. Right. Apologies for the misuse of 'trunk'. Would it be possible to
include this feature in GRASS65?
Comment (by cmbarton):
Not using a graphical user interface means typing controlling a module via
typed commands (i.e. on the command line). Being able to enter screen x
and y coordinates and return a bearing and distance could be useful; it
might make GUI programming easier in fact. Using the command line is very
useful for a variety of GIS functions of course and essential for
scripting.
d.measure is a GUI, but a very antiquated one. That is, it allows a user
to interact with a graphic display using a mouse or other pointing device.
Maintaining this very old, platform specific GUI in C (i.e., it requires
an xterm environment that emulates even older graphic hardware displays)
is problematic for a variety of other functions, as well as for having a
consistent command line behavior in which the user types a command and the
module creates a map, a graphic output, or returns text. We now have a GUI
that is about 3 generations past the d.measure GUI environment that sits
on top of the command line GRASS interface. Users can type all the
commands they want without interference from the GUI. When the user wants
to interact with the program graphically, the GUI can be used (or invoked
if previously closed). Given all this, I can't see the reason to maintain
an alternative, very old GUI for xterms only.
Comment (by neteler):
Replying to [comment:8 cmbarton]:
via typed commands (i.e. on the command line). Being able to enter screen
x and y coordinates and return a bearing and distance could be useful; it
scripting.
Comment (by hamish):
everything is already there for command line use from r.transect,
r.profile, as Markus points out m.cogo (although that is primarily
designed to mirror US survey definitions), and * swig/python/m.distance.py
also there is code in d.geodesic and d.rhumbline to play with.
